AMD Bulldozer Finally!
The PII ? I am indeed, I have to be at this point in life now that I ask - is it enough to run what I want ? YES it is, my love for epic PC stuff will have to sit on the sidelines, saying that I do sometimes wish lightroom was faster, ivy bridge it is :p
I actually meant that for Gareth. :p
That 1055T you have can take its CPU NB to 3.2GHZ, that's higher than the average, it's kind of funny, that 1055T OC'ed to its limit will trounce the FX8 in real world app's for the majority of the time.
i don't think so
i thought it would performance a lot better in dvdfab as that a 8 threaded app also afew others
Really that bad?
You will see quite a difference with the 2600k when it's OC'ed to the maximum :p
It's almost like AMD have had their heads buried in the sand and forgot the performance their own chips, and Intels offered.
And they wanted 220 quid originally for that piece of crap.
After seeing the benchies from Garaeth I have to say that from AMD's point of view it must be an epic and I mean EPIC face palm
Glad you stuck to your guns m8 on this good for you dude!
Stoner81.
log
# Windows GUI 0.9.5 2011010300
# Running: Microsoft Windows NT 6.1.7600.0
# CPU: AMD FX(tm)-8150 Eight-Core Processor
# Ram: 4056 MB
# Screen: 1920x1080
# Temp Dir: G:\Temp\
# Install Dir: C:\Program Files (x86)\Handbrake
# Data Dir: C:\Users\gareth\AppData\Roaming\HandBrake\HandBrake\0.9.5.3728
# CLI Query: -i "G:\downloads\Tron_Trailer_HD.mov" -t 1 -c 1 -o "G:\mkv\Tron_Trailer_HD.mkv" -f mkv --strict-anamorphic -e x264 -q 20 -a 1 -E faac -6 dpl2 -R Auto -B 160 -D 0.0 -x ref=2:bframes=2:subq=6:mixed-refs=0:weightb=0:8x8dct=0:trellis=0 --verbose=1
# User Query: False
[12:06:42] hb_init: checking cpu count
[12:06:42] hb_init: starting libhb thread
HandBrake 0.9.5 (2011010300) - MinGW i386 - http://handbrake.fr
8 CPUs detected
Opening G:\downloads\Tron_Trailer_HD.mov...
[12:06:42] hb_scan: path=G:\downloads\Tron_Trailer_HD.mov, title_index=1
libbluray/bdnav/index_parse.c:157: indx_parse(): error opening G:\downloads\Tron_Trailer_HD.mov/BDMV/index.bdmv
libbluray/bluray.c:960: nav_get_title_list(G:\downloads\Tron_Trailer_HD.mov) failed (0x1a5a6f8)
[12:06:42] bd: not a bd - trying as a stream/file instead
libdvdnav: Using dvdnav version 4.1.3
libdvdread: Encrypted DVD support unavailable.
libdvdnav VDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.IFO failed
libdvdnav VDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.BUP failed
libdvdread: Can't open file VIDEO_TS.IFO.
libdvdnav: vm: failed to read VIDEO_TS.IFO
[12:06:42] dvd: not a dvd - trying as a stream/file instead
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'G:\downloads\Tron_Trailer_HD.mov':
Metadata:
copyright : © Disney
copyright-eng : © Disney
comment : Im Verleih der Walt Disney Studios Motion Pictures
comment-eng : Im Verleih der Walt Disney Studios Motion Pictures
title : TRON - LEGACY
title-eng : TRON - LEGACY
Duration: 00:02:28.84, start: 0.000000, bitrate: 15237 kb/s
Stream #0.0(eng): Video: h264, yuv420p, 1920x816 [PAR 1:1 DAR 40:17], 14914 kb/s, 24 fps, 24 tbr, 600 tbn, 48 tbc
Stream #0.1(eng): Audio: aac, 44100 Hz, stereo, s16, 320 kb/s
[12:06:42] scan: decoding previews for title 1
Scanning title 1...
Scanning title 1...
Scanning title 1...
[12:06:43] scan: 10 previews, 1920x816, 24.000 fps, autocrop = 0/0/0/0, aspect 2.35:1, PAR 1:1
[12:06:43] scan: title (0) job->width:1920, job->height:816
[12:06:43] libhb: scan thread found 1 valid title(s)
+ title 1:
+ stream: G:\downloads\Tron_Trailer_HD.mov
+ duration: 00:02:28
+ size: 1920x816, pixel aspect: 1/1, display aspect: 2.35, 24.000 fps
+ autocrop: 0/0/0/0
+ chapters:
+ 1: cells 0->0, 0 blocks, duration 00:02:28
+ audio tracks:
+ 1, English (AAC) (2.0 ch) (iso639-2: eng)
+ subtitle tracks:
[12:06:43] 1 job(s) to process
[12:06:43] starting job
[12:06:43] work: sanitizing track 0 mixdown Dolby Pro Logic II to Stereo
[12:06:43] sync: expecting 3596 video frames
[12:06:43] job configuration:
[12:06:43] * source
[12:06:43] + G:\downloads\Tron_Trailer_HD.mov
[12:06:43] + title 1, chapter(s) 1 to 1
[12:06:43] + container: mov,mp4,m4a,3gp,3g2,mj2
[12:06:43] + data rate: 15237 kbps
[12:06:43] * destination
[12:06:43] + G:\mkv\Tron_Trailer_HD.mkv
[12:06:43] + container: Matroska (.mkv)
[12:06:43] * video track
[12:06:43] + decoder: h264
[12:06:43] + bitrate 14914 kbps
[12:06:43] + frame rate: same as source (around 24.000 fps)
[12:06:43] + strict anamorphic
[12:06:43] + storage dimensions: 1920 * 816 -> 1920 * 816, crop 0/0/0/0, mod 0
[12:06:43] + pixel aspect ratio: 1 / 1
[12:06:43] + display dimensions: 1920 * 816
[12:06:43] + encoder: x264
[12:06:43] + options: ref=2:bframes=2:subq=6:mixed-refs=0:weightb=0:8x8dct=0:trellis=0
[12:06:43] + quality: 20.00 (RF)
[12:06:43] * audio track 0
[12:06:43] + decoder: English (AAC) (2.0 ch) (track 1, id 1)
[12:06:43] + mixdown: Stereo
[12:06:43] + encoder: faac
[12:06:43] + bitrate: 160 kbps, samplerate: 44100 Hz
[12:06:43] encx264: min-keyint: auto (24), keyint: 240
[12:06:43] encx264: encoding with stored aspect 1/1
[12:06:43] encx264: Encoding at constant RF 20.000000
x264 [info]: using SAR=1/1
x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.2 SSEMisalign LZCNT
[12:06:43] reader: first SCR 0 id 0 DTS 0
x264 [info]: profile Main, level 4.0
[12:08:18] reader: done. 1 scr changes
[12:08:20] work: average encoding speed for job is 37.410057 fps
[12:08:20] sync: got 3572 frames, 3596 expected
[12:08:20] h264-decoder done: 3572 frames, 0 decoder errors, 0 drops
[12:08:20] render: lost time: 0 (0 frames)
[12:08:20] render: gained time: 0 (0 frames) (0 not accounted for)
x264 [info]: frame I:104 Avg QP:16.63 size: 95879 PSNR Mean Y:51.19 U:55.75 V:56.69 Avg:52.20 Global:50.57
x264 [info]: frame P:2468 Avg QP:19.74 size: 27156 PSNR Mean Y:47.92 U:52.37 V:53.09 Avg:48.88 Global:47.14
x264 [info]: frame B:1000 Avg QP:21.48 size: 10221 PSNR Mean Y:50.94 U:55.33 V:56.07 Avg:51.81 Global:46.57
x264 [info]: consecutive B-frames: 49.3% 29.6% 21.0%
x264 [info]: mb I I16..4: 59.4% 0.0% 40.6%
x264 [info]: mb P I16..4: 25.9% 0.0% 5.1% P16..4: 39.8% 6.0% 3.0% 0.0% 0.0% skip:20.1%
x264 [info]: mb B I16..4: 10.3% 0.0% 0.5% B16..8: 21.2% 3.5% 0.3% direct: 9.0% skip:55.3% L0:39.1% L1:49.6% BI:11.3%
x264 [info]: coded y,uvDC,uvAC intra: 41.2% 50.0% 23.2% inter: 10.7% 23.7% 1.4%
x264 [info]: i16 v,h,dc,p: 34% 24% 25% 16%
x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 19% 25% 29% 5% 6% 5% 5% 4% 4%
x264 [info]: i8c dc,h,v,p: 58% 21% 16% 6%
x264 [info]: Weighted P-Frames: Y:16.1% UV:11.7%
x264 [info]: ref P L0: 62.7% 9.1% 26.9% 1.4%
x264 [info]: ref B L0: 67.8% 32.2%
x264 [info]: ref B L1: 95.0% 5.0%
x264 [info]: SSIM Mean Y:0.9863832 (18.659db)
x264 [info]: PSNR Mean Y:48.863 U:53.295 V:54.028 Avg:49.797 Global:47.037 kb/s:4686.59
[12:08:20] aac-decoder done: 0 frames, 0 decoder errors, 0 drops
[12:08:20] mux: track 0, 3572 frames, 87211359 bytes, 4685.11 kbps, fifo 8
[12:08:20] mux: track 1, 6413 frames, 2892381 bytes, 155.38 kbps, fifo 512
[12:08:20] libhb: work result = 0
Rip done!
HandBrake has exited.
Thanks!
The Tron trailer encode speed is 37.41FPS which puts in between a Phenom II X6 1100T(33.74FPS) and a Xeon E3-1270(39.4FPS). The Xeon E3-1270 is essentially the same CPU as a Core i7 2600K but with the IGP switched off. However,looking at table a Phenom II X6 at similar speeds would be around the same.
log
# Ram: 4056 MB
# Screen: 1920x1080
# CLI Query: -i "G:\downloads\Splice_Trlr_1_1080P.wmv" -t 1 -c 1 -o "G:\mkv\Splice_Trlr_1_1080P.mkv" -f mkv --strict-anamorphic -e x264 -q 20 -a 1 -E faac -6 dpl2 -R Auto -B 160 -D 0.0 -x ref=2:bframes=2:subq=6:mixed-refs=0:weightb=0:8x8dct=0:trellis=0 --verbose=1
# User Query: False
[12:32:14] hb_init: checking cpu count
[12:32:14] hb_init: starting libhb thread
8 CPUs detected
Opening G:\downloads\Splice_Trlr_1_1080P.wmv...
[12:32:14] hb_scan: path=G:\downloads\Splice_Trlr_1_1080P.wmv, title_index=1
libbluray/bdnav/index_parse.c:157: indx_parse(): error opening G:\downloads\Splice_Trlr_1_1080P.wmv/BDMV/index.bdmv
libbluray/bluray.c:960: nav_get_title_list(G:\downloads\Splice_Trlr_1_1080P.wmv) failed (0x1a3a9e0)
[12:32:14] bd: not a bd - trying as a stream/file instead
libdvdnav:DVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.IFO failed
libdvdnav:DVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.BUP failed
[12:32:14] dvd: not a dvd - trying as a stream/file instead
Input #0, asf, from 'G:\downloads\Splice_Trlr_1_1080P.wmv':
Metadata:
WM/ToolName : Flip4Mac WMV Export Component for QuickTime (Mac)
WM/ToolVersion : 2312_0í˜ëŒ•耸í편ロ掸掺
title :
artist :
copyright :
comment :
Duration: 00:02:17.04, start: 5.000000, bitrate: 20572 kb/s
Stream #0.0(eng): Audio: wmav2, 44100 Hz, 2 channels, s16, 192 kb/s
Stream #0.1(eng): Video: vc1, yuv420p, 1920x1080, 20338 kb/s, 23.98 tbr, 1k tbn, 1k tbc
[12:32:14] scan: decoding previews for title 1
Scanning title 1...
Scanning title 1...
[12:32:14] scan: 10 previews, 1920x1080, 23.976 fps, autocrop = 0/0/0/0, aspect 16:9, PAR 1:1
[12:32:14] scan: title (0) job->width:1920, job->height:1072
[12:32:14] libhb: scan thread found 1 valid title(s)
+ title 1:
+ stream: G:\downloads\Splice_Trlr_1_1080P.wmv
+ duration: 00:02:17
+ size: 1920x1080, pixel aspect: 1/1, display aspect: 1.78, 23.976 fps
+ autocrop: 0/0/0/0
+ chapters:
+ 1: cells 0->0, 0 blocks, duration 00:02:17
+ audio tracks:
+ 1, English (WMAV2) (2.0 ch) (iso639-2: eng)
+ subtitle tracks:
[12:32:14] 1 job(s) to process
[12:32:14] starting job
[12:32:14] work: sanitizing track 0 mixdown Dolby Pro Logic II to Stereo
[12:32:14] sync: expecting 3309 video frames
[12:32:14] job configuration:
[12:32:14] * source
[12:32:14] + G:\downloads\Splice_Trlr_1_1080P.wmv
[12:32:14] + title 1, chapter(s) 1 to 1
[12:32:14] + container: asf
[12:32:14] + data rate: 20572 kbps
[12:32:14] * destination
[12:32:14] + G:\mkv\Splice_Trlr_1_1080P.mkv
[12:32:14] + container: Matroska (.mkv)
[12:32:14] * video track
[12:32:14] + decoder: vc1
[12:32:14] + bitrate 20338 kbps
[12:32:14] + frame rate: same as source (around 23.976 fps)
[12:32:14] + strict anamorphic
[12:32:14] + storage dimensions: 1920 * 1080 -> 1920 * 1080, crop 0/0/0/0, mod 0
[12:32:14] + pixel aspect ratio: 1 / 1
[12:32:14] + display dimensions: 1920 * 1080
[12:32:14] + encoder: x264
[12:32:14] + options: ref=2:bframes=2:subq=6:mixed-refs=0:weightb=0:8x8dct=0:trellis=0
[12:32:14] + quality: 20.00 (RF)
[12:32:14] * audio track 0
[12:32:14] + decoder: English (WMAV2) (2.0 ch) (track 1, id 0)
[12:32:14] + mixdown: Stereo
[12:32:14] + encoder: faac
[12:32:14] + bitrate: 160 kbps, samplerate: 44100 Hz
[12:32:14] encx264: min-keyint: auto (23), keyint: 240
[12:32:14] encx264: encoding with stored aspect 1/1
[12:32:14] encx264: Encoding at constant RF 20.000000
[12:32:14] reader: first SCR 450000 id 0 DTS 450000
[12:34:17] reader: done. 1 scr changes
[12:34:19] work: average encoding speed for job is 26.385181 fps
[12:34:19] sync: got 3288 frames, 3309 expected
[12:34:19] vc1-decoder done: 3288 frames, 0 decoder errors, 0 drops
[12:34:19] render: lost time: 0 (0 frames)
[12:34:19] render: gained time: 0 (0 frames) (0 not accounted for)
x264 [info]: frame I:111 Avg QP:17.62 size:171814 PSNR Mean Y:48.22 U:49.06 V:48.81 Avg:48.37 Global:46.72
x264 [info]: frame P:2071 Avg QP:20.10 size: 59208 PSNR Mean Y:49.55 U:49.62 V:48.99 Avg:49.33 Global:44.61
x264 [info]: frame B:1106 Avg QP:21.08 size: 18838 PSNR Mean Y:57.88 U:57.15 V:55.88 Avg:56.98 Global:45.94
x264 [info]: consecutive B-frames: 41.1% 26.7% 32.2%
x264 [info]: mb I I16..4: 38.6% 0.0% 61.4%
x264 [info]: mb P I16..4: 11.7% 0.0% 7.3% P16..4: 47.6% 10.2% 4.6% 0.0% 0.0% skip:18.6%
x264 [info]: mb B I16..4: 6.4% 0.0% 0.4% B16..8: 18.3% 3.9% 0.2% direct:12.1% skip:58.8% L0:44.5% L1:45.8% BI: 9.6%
x264 [info]: coded y,uvDC,uvAC intra: 48.8% 75.3% 62.5% inter: 18.6% 45.0% 21.3%
x264 [info]: i16 v,h,dc,p: 53% 14% 15% 18%
x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 23% 17% 24% 6% 8% 7% 6% 5% 4%
x264 [info]: i8c dc,h,v,p: 61% 14% 16% 9%
x264 [info]: Weighted P-Frames: Y:10.9% UV:9.2%
x264 [info]: ref P L0: 70.6% 11.6% 17.4% 0.4%
x264 [info]: ref B L0: 81.2% 18.8%
x264 [info]: ref B L1: 97.0% 3.0%
x264 [info]: SSIM Mean Y:0.9819091 (17.425db)
x264 [info]: PSNR Mean Y:52.309 U:52.134 V:51.304 Avg:51.872 Global:45.073 kb/s:9478.62
[12:34:20] wmav2-decoder done: 0 frames, 0 decoder errors, 0 drops
[12:34:20] mux: track 0, 3288 frames, 162522539 bytes, 9472.24 kbps, fifo 8
[12:34:20] mux: track 1, 5911 frames, 2745965 bytes, 160.04 kbps, fifo 512
[12:34:20] libhb: work result = 0
Rip done!
Thanks again!!
23.976FPS with the Splice Trailer. This puts it slightly above a Phenom II X6 1090T. Again it looks like a 3.6GHZ Phenom II X6 would produce a similar result.
There is one more trailer on the chart but it is a 886MB download. Any chance of running this one too:
http://www.bigbuckbunny.org/index.php/download/
Its the 1080p 1920X1080 Big Buck Bunny trailer.
Can I also include the results in the table??
