AMD Bulldozer Finally!
log
# Windows GUI 0.9.5 2011010300
# Running: Microsoft Windows NT 6.1.7600.0
# CPU: AMD FX(tm)-8150 Eight-Core Processor
# Ram: 4056 MB
# Screen: 1920x1080
# Temp Dir: G:\Temp\
# Install Dir: C:\Program Files (x86)\Handbrake
# Data Dir: C:\Users\gareth\AppData\Roaming\HandBrake\HandBrake\0.9.5.3728
# CLI Query: -i "G:\downloads\Tron_Trailer_HD.mov" -t 1 -c 1 -o "G:\mkv\Tron_Trailer_HD.mkv" -f mkv --strict-anamorphic -e x264 -q 20 -a 1 -E faac -6 dpl2 -R Auto -B 160 -D 0.0 -x ref=2:bframes=2:subq=6:mixed-refs=0:weightb=0:8x8dct=0:trellis=0 --verbose=1
# User Query: False
[12:06:42] hb_init: checking cpu count
[12:06:42] hb_init: starting libhb thread
HandBrake 0.9.5 (2011010300) - MinGW i386 - http://handbrake.fr
8 CPUs detected
Opening G:\downloads\Tron_Trailer_HD.mov...
[12:06:42] hb_scan: path=G:\downloads\Tron_Trailer_HD.mov, title_index=1
libbluray/bdnav/index_parse.c:157: indx_parse(): error opening G:\downloads\Tron_Trailer_HD.mov/BDMV/index.bdmv
libbluray/bluray.c:960: nav_get_title_list(G:\downloads\Tron_Trailer_HD.mov) failed (0x1a5a6f8)
[12:06:42] bd: not a bd - trying as a stream/file instead
libdvdnav: Using dvdnav version 4.1.3
libdvdread: Encrypted DVD support unavailable.
libdvdnav VDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.IFO failed
libdvdnav VDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.BUP failed
libdvdread: Can't open file VIDEO_TS.IFO.
libdvdnav: vm: failed to read VIDEO_TS.IFO
[12:06:42] dvd: not a dvd - trying as a stream/file instead
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'G:\downloads\Tron_Trailer_HD.mov':
Metadata:
copyright : © Disney
copyright-eng : © Disney
comment : Im Verleih der Walt Disney Studios Motion Pictures
comment-eng : Im Verleih der Walt Disney Studios Motion Pictures
title : TRON - LEGACY
title-eng : TRON - LEGACY
Duration: 00:02:28.84, start: 0.000000, bitrate: 15237 kb/s
Stream #0.0(eng): Video: h264, yuv420p, 1920x816 [PAR 1:1 DAR 40:17], 14914 kb/s, 24 fps, 24 tbr, 600 tbn, 48 tbc
Stream #0.1(eng): Audio: aac, 44100 Hz, stereo, s16, 320 kb/s
[12:06:42] scan: decoding previews for title 1
Scanning title 1...
Scanning title 1...
Scanning title 1...
[12:06:43] scan: 10 previews, 1920x816, 24.000 fps, autocrop = 0/0/0/0, aspect 2.35:1, PAR 1:1
[12:06:43] scan: title (0) job->width:1920, job->height:816
[12:06:43] libhb: scan thread found 1 valid title(s)
+ title 1:
+ stream: G:\downloads\Tron_Trailer_HD.mov
+ duration: 00:02:28
+ size: 1920x816, pixel aspect: 1/1, display aspect: 2.35, 24.000 fps
+ autocrop: 0/0/0/0
+ chapters:
+ 1: cells 0->0, 0 blocks, duration 00:02:28
+ audio tracks:
+ 1, English (AAC) (2.0 ch) (iso639-2: eng)
+ subtitle tracks:
[12:06:43] 1 job(s) to process
[12:06:43] starting job
[12:06:43] work: sanitizing track 0 mixdown Dolby Pro Logic II to Stereo
[12:06:43] sync: expecting 3596 video frames
[12:06:43] job configuration:
[12:06:43] * source
[12:06:43] + G:\downloads\Tron_Trailer_HD.mov
[12:06:43] + title 1, chapter(s) 1 to 1
[12:06:43] + container: mov,mp4,m4a,3gp,3g2,mj2
[12:06:43] + data rate: 15237 kbps
[12:06:43] * destination
[12:06:43] + G:\mkv\Tron_Trailer_HD.mkv
[12:06:43] + container: Matroska (.mkv)
[12:06:43] * video track
[12:06:43] + decoder: h264
[12:06:43] + bitrate 14914 kbps
[12:06:43] + frame rate: same as source (around 24.000 fps)
[12:06:43] + strict anamorphic
[12:06:43] + storage dimensions: 1920 * 816 -> 1920 * 816, crop 0/0/0/0, mod 0
[12:06:43] + pixel aspect ratio: 1 / 1
[12:06:43] + display dimensions: 1920 * 816
[12:06:43] + encoder: x264
[12:06:43] + options: ref=2:bframes=2:subq=6:mixed-refs=0:weightb=0:8x8dct=0:trellis=0
[12:06:43] + quality: 20.00 (RF)
[12:06:43] * audio track 0
[12:06:43] + decoder: English (AAC) (2.0 ch) (track 1, id 1)
[12:06:43] + mixdown: Stereo
[12:06:43] + encoder: faac
[12:06:43] + bitrate: 160 kbps, samplerate: 44100 Hz
[12:06:43] encx264: min-keyint: auto (24), keyint: 240
[12:06:43] encx264: encoding with stored aspect 1/1
[12:06:43] encx264: Encoding at constant RF 20.000000
x264 [info]: using SAR=1/1
x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.2 SSEMisalign LZCNT
[12:06:43] reader: first SCR 0 id 0 DTS 0
x264 [info]: profile Main, level 4.0
[12:08:18] reader: done. 1 scr changes
[12:08:20] work: average encoding speed for job is 37.410057 fps
[12:08:20] sync: got 3572 frames, 3596 expected
[12:08:20] h264-decoder done: 3572 frames, 0 decoder errors, 0 drops
[12:08:20] render: lost time: 0 (0 frames)
[12:08:20] render: gained time: 0 (0 frames) (0 not accounted for)
x264 [info]: frame I:104 Avg QP:16.63 size: 95879 PSNR Mean Y:51.19 U:55.75 V:56.69 Avg:52.20 Global:50.57
x264 [info]: frame P:2468 Avg QP:19.74 size: 27156 PSNR Mean Y:47.92 U:52.37 V:53.09 Avg:48.88 Global:47.14
x264 [info]: frame B:1000 Avg QP:21.48 size: 10221 PSNR Mean Y:50.94 U:55.33 V:56.07 Avg:51.81 Global:46.57
x264 [info]: consecutive B-frames: 49.3% 29.6% 21.0%
x264 [info]: mb I I16..4: 59.4% 0.0% 40.6%
x264 [info]: mb P I16..4: 25.9% 0.0% 5.1% P16..4: 39.8% 6.0% 3.0% 0.0% 0.0% skip:20.1%
x264 [info]: mb B I16..4: 10.3% 0.0% 0.5% B16..8: 21.2% 3.5% 0.3% direct: 9.0% skip:55.3% L0:39.1% L1:49.6% BI:11.3%
x264 [info]: coded y,uvDC,uvAC intra: 41.2% 50.0% 23.2% inter: 10.7% 23.7% 1.4%
x264 [info]: i16 v,h,dc,p: 34% 24% 25% 16%
x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 19% 25% 29% 5% 6% 5% 5% 4% 4%
x264 [info]: i8c dc,h,v,p: 58% 21% 16% 6%
x264 [info]: Weighted P-Frames: Y:16.1% UV:11.7%
x264 [info]: ref P L0: 62.7% 9.1% 26.9% 1.4%
x264 [info]: ref B L0: 67.8% 32.2%
x264 [info]: ref B L1: 95.0% 5.0%
x264 [info]: SSIM Mean Y:0.9863832 (18.659db)
x264 [info]: PSNR Mean Y:48.863 U:53.295 V:54.028 Avg:49.797 Global:47.037 kb/s:4686.59
[12:08:20] aac-decoder done: 0 frames, 0 decoder errors, 0 drops
[12:08:20] mux: track 0, 3572 frames, 87211359 bytes, 4685.11 kbps, fifo 8
[12:08:20] mux: track 1, 6413 frames, 2892381 bytes, 155.38 kbps, fifo 512
[12:08:20] libhb: work result = 0
Rip done!
HandBrake has exited.
Thanks!
The Tron trailer encode speed is 37.41FPS which puts in between a Phenom II X6 1100T(33.74FPS) and a Xeon E3-1270(39.4FPS). The Xeon E3-1270 is essentially the same CPU as a Core i7 2600K but with the IGP switched off. However,looking at table a Phenom II X6 at similar speeds would be around the same.
log
# Ram: 4056 MB
# Screen: 1920x1080
# CLI Query: -i "G:\downloads\Splice_Trlr_1_1080P.wmv" -t 1 -c 1 -o "G:\mkv\Splice_Trlr_1_1080P.mkv" -f mkv --strict-anamorphic -e x264 -q 20 -a 1 -E faac -6 dpl2 -R Auto -B 160 -D 0.0 -x ref=2:bframes=2:subq=6:mixed-refs=0:weightb=0:8x8dct=0:trellis=0 --verbose=1
# User Query: False
[12:32:14] hb_init: checking cpu count
[12:32:14] hb_init: starting libhb thread
8 CPUs detected
Opening G:\downloads\Splice_Trlr_1_1080P.wmv...
[12:32:14] hb_scan: path=G:\downloads\Splice_Trlr_1_1080P.wmv, title_index=1
libbluray/bdnav/index_parse.c:157: indx_parse(): error opening G:\downloads\Splice_Trlr_1_1080P.wmv/BDMV/index.bdmv
libbluray/bluray.c:960: nav_get_title_list(G:\downloads\Splice_Trlr_1_1080P.wmv) failed (0x1a3a9e0)
[12:32:14] bd: not a bd - trying as a stream/file instead
libdvdnav:DVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.IFO failed
libdvdnav:DVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.BUP failed
[12:32:14] dvd: not a dvd - trying as a stream/file instead
Input #0, asf, from 'G:\downloads\Splice_Trlr_1_1080P.wmv':
Metadata:
WM/ToolName : Flip4Mac WMV Export Component for QuickTime (Mac)
WM/ToolVersion : 2312_0í˜ëŒ•耸í편ロ掸掺
title :
artist :
copyright :
comment :
Duration: 00:02:17.04, start: 5.000000, bitrate: 20572 kb/s
Stream #0.0(eng): Audio: wmav2, 44100 Hz, 2 channels, s16, 192 kb/s
Stream #0.1(eng): Video: vc1, yuv420p, 1920x1080, 20338 kb/s, 23.98 tbr, 1k tbn, 1k tbc
[12:32:14] scan: decoding previews for title 1
Scanning title 1...
Scanning title 1...
[12:32:14] scan: 10 previews, 1920x1080, 23.976 fps, autocrop = 0/0/0/0, aspect 16:9, PAR 1:1
[12:32:14] scan: title (0) job->width:1920, job->height:1072
[12:32:14] libhb: scan thread found 1 valid title(s)
+ title 1:
+ stream: G:\downloads\Splice_Trlr_1_1080P.wmv
+ duration: 00:02:17
+ size: 1920x1080, pixel aspect: 1/1, display aspect: 1.78, 23.976 fps
+ autocrop: 0/0/0/0
+ chapters:
+ 1: cells 0->0, 0 blocks, duration 00:02:17
+ audio tracks:
+ 1, English (WMAV2) (2.0 ch) (iso639-2: eng)
+ subtitle tracks:
[12:32:14] 1 job(s) to process
[12:32:14] starting job
[12:32:14] work: sanitizing track 0 mixdown Dolby Pro Logic II to Stereo
[12:32:14] sync: expecting 3309 video frames
[12:32:14] job configuration:
[12:32:14] * source
[12:32:14] + G:\downloads\Splice_Trlr_1_1080P.wmv
[12:32:14] + title 1, chapter(s) 1 to 1
[12:32:14] + container: asf
[12:32:14] + data rate: 20572 kbps
[12:32:14] * destination
[12:32:14] + G:\mkv\Splice_Trlr_1_1080P.mkv
[12:32:14] + container: Matroska (.mkv)
[12:32:14] * video track
[12:32:14] + decoder: vc1
[12:32:14] + bitrate 20338 kbps
[12:32:14] + frame rate: same as source (around 23.976 fps)
[12:32:14] + strict anamorphic
[12:32:14] + storage dimensions: 1920 * 1080 -> 1920 * 1080, crop 0/0/0/0, mod 0
[12:32:14] + pixel aspect ratio: 1 / 1
[12:32:14] + display dimensions: 1920 * 1080
[12:32:14] + encoder: x264
[12:32:14] + options: ref=2:bframes=2:subq=6:mixed-refs=0:weightb=0:8x8dct=0:trellis=0
[12:32:14] + quality: 20.00 (RF)
[12:32:14] * audio track 0
[12:32:14] + decoder: English (WMAV2) (2.0 ch) (track 1, id 0)
[12:32:14] + mixdown: Stereo
[12:32:14] + encoder: faac
[12:32:14] + bitrate: 160 kbps, samplerate: 44100 Hz
[12:32:14] encx264: min-keyint: auto (23), keyint: 240
[12:32:14] encx264: encoding with stored aspect 1/1
[12:32:14] encx264: Encoding at constant RF 20.000000
[12:32:14] reader: first SCR 450000 id 0 DTS 450000
[12:34:17] reader: done. 1 scr changes
[12:34:19] work: average encoding speed for job is 26.385181 fps
[12:34:19] sync: got 3288 frames, 3309 expected
[12:34:19] vc1-decoder done: 3288 frames, 0 decoder errors, 0 drops
[12:34:19] render: lost time: 0 (0 frames)
[12:34:19] render: gained time: 0 (0 frames) (0 not accounted for)
x264 [info]: frame I:111 Avg QP:17.62 size:171814 PSNR Mean Y:48.22 U:49.06 V:48.81 Avg:48.37 Global:46.72
x264 [info]: frame P:2071 Avg QP:20.10 size: 59208 PSNR Mean Y:49.55 U:49.62 V:48.99 Avg:49.33 Global:44.61
x264 [info]: frame B:1106 Avg QP:21.08 size: 18838 PSNR Mean Y:57.88 U:57.15 V:55.88 Avg:56.98 Global:45.94
x264 [info]: consecutive B-frames: 41.1% 26.7% 32.2%
x264 [info]: mb I I16..4: 38.6% 0.0% 61.4%
x264 [info]: mb P I16..4: 11.7% 0.0% 7.3% P16..4: 47.6% 10.2% 4.6% 0.0% 0.0% skip:18.6%
x264 [info]: mb B I16..4: 6.4% 0.0% 0.4% B16..8: 18.3% 3.9% 0.2% direct:12.1% skip:58.8% L0:44.5% L1:45.8% BI: 9.6%
x264 [info]: coded y,uvDC,uvAC intra: 48.8% 75.3% 62.5% inter: 18.6% 45.0% 21.3%
x264 [info]: i16 v,h,dc,p: 53% 14% 15% 18%
x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 23% 17% 24% 6% 8% 7% 6% 5% 4%
x264 [info]: i8c dc,h,v,p: 61% 14% 16% 9%
x264 [info]: Weighted P-Frames: Y:10.9% UV:9.2%
x264 [info]: ref P L0: 70.6% 11.6% 17.4% 0.4%
x264 [info]: ref B L0: 81.2% 18.8%
x264 [info]: ref B L1: 97.0% 3.0%
x264 [info]: SSIM Mean Y:0.9819091 (17.425db)
x264 [info]: PSNR Mean Y:52.309 U:52.134 V:51.304 Avg:51.872 Global:45.073 kb/s:9478.62
[12:34:20] wmav2-decoder done: 0 frames, 0 decoder errors, 0 drops
[12:34:20] mux: track 0, 3288 frames, 162522539 bytes, 9472.24 kbps, fifo 8
[12:34:20] mux: track 1, 5911 frames, 2745965 bytes, 160.04 kbps, fifo 512
[12:34:20] libhb: work result = 0
Rip done!
Thanks again!!
23.976FPS with the Splice Trailer. This puts it slightly above a Phenom II X6 1090T. Again it looks like a 3.6GHZ Phenom II X6 would produce a similar result.
There is one more trailer on the chart but it is a 886MB download. Any chance of running this one too:
http://www.bigbuckbunny.org/index.php/download/
Its the 1080p 1920X1080 Big Buck Bunny trailer.
Can I also include the results in the table??
Thanks again!!
yeah mate
yeah mate
you mean the mp4 one?
Yep,it should be a 886MB MP4 file.
The Tron trailer is a MOV file,the Splice Trailer is a WMV file and the Big Bunny short film is a MP4 file and all encoded to MKV format.
BTW,did you set the HandBrake priority to high in the settings menu??
Again,thanks for taking the time to run these encodes(much appreciated).
yeah . did u want it on below normal (default)? if so, im sorry
the Big Bunny short film MP4 link downloads as avi
# Ram: 4056 MB
# Screen: 1920x1080
# CLI Query: -i "G:\downloads\big_buck_bunny_1080p_surround.avi" -t 1 -c 1 -o "G:\mkv\big_buck_bunny_1080p_surround.mkv" -f mkv --strict-anamorphic -e x264 -q 20 -a 1 -E faac -6 dpl2 -R Auto -B 160 -D 0.0 -x ref=2:bframes=2:subq=6:mixed-refs=0:weightb=0:8x8dct=0:trellis=0 --verbose=1
# User Query: False
[13:01:08] hb_init: checking cpu count
[13:01:08] hb_init: starting libhb thread
8 CPUs detected
Opening G:\downloads\big_buck_bunny_1080p_surround.avi...
[13:01:08] hb_scan: path=G:\downloads\big_buck_bunny_1080p_surround.avi, title_index=1
libbluray/bdnav/index_parse.c:157: indx_parse(): error opening G:\downloads\big_buck_bunny_1080p_surround.avi/BDMV/index.bdmv
libbluray/bluray.c:960: nav_get_title_list(G:\downloads\big_buck_bunny_1080p_surround.avi) failed (0x1b4aa20)
[13:01:08] bd: not a bd - trying as a stream/file instead
[13:01:08] dvd: not a dvd - trying as a stream/file instead
Input #0, avi, from 'G:\downloads\big_buck_bunny_1080p_surround.avi':
Metadata:
encoder : AVI-Mux GUI 1.17.7, Aug 8 2006 20:59:17
JUNK :
Duration: 00:09:56.45, start: 0.000000, bitrate: 12455 kb/s
Stream #0.0: Video: mpeg4, yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 24 tbr, 24 tbn, 24 tbc
Stream #0.1: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
[13:01:08] scan: decoding previews for title 1
[13:01:08] scan: audio 0x1: AC-3, rate=48000Hz, bitrate=448000 Unknown (AC3) (5.1 ch)
Scanning title 1...
[13:01:08] scan: 10 previews, 1920x1080, 24.000 fps, autocrop = 0/0/0/0, aspect 16:9, PAR 1:1
[13:01:08] scan: title (0) job->width:1920, job->height:1072
[13:01:08] libhb: scan thread found 1 valid title(s)
+ title 1:
+ stream: G:\downloads\big_buck_bunny_1080p_surround.avi
+ duration: 00:09:56
+ size: 1920x1080, pixel aspect: 1/1, display aspect: 1.78, 24.000 fps
+ autocrop: 0/0/0/0
+ chapters:
+ 1: cells 0->0, 0 blocks, duration 00:09:56
+ audio tracks:
+ 1, Unknown (AC3) (5.1 ch) (iso639-2: und), 48000Hz, 448000bps
+ subtitle tracks:
[13:01:08] 1 job(s) to process
[13:01:08] starting job
[13:01:08] sync: expecting 14339 video frames
[13:01:08] job configuration:
[13:01:08] * source
[13:01:08] + G:\downloads\big_buck_bunny_1080p_surround.avi
[13:01:08] + title 1, chapter(s) 1 to 1
[13:01:08] + container: avi
[13:01:08] + data rate: 12455 kbps
[13:01:08] * destination
[13:01:08] + G:\mkv\big_buck_bunny_1080p_surround.mkv
[13:01:08] + container: Matroska (.mkv)
[13:01:08] * video track
[13:01:08] + decoder: mpeg4
[13:01:08] + frame rate: same as source (around 24.000 fps)
[13:01:08] + strict anamorphic
[13:01:08] + storage dimensions: 1920 * 1080 -> 1920 * 1080, crop 0/0/0/0, mod 0
[13:01:08] + pixel aspect ratio: 1 / 1
[13:01:08] + display dimensions: 1920 * 1080
[13:01:08] + encoder: x264
[13:01:08] + options: ref=2:bframes=2:subq=6:mixed-refs=0:weightb=0:8x8dct=0:trellis=0
[13:01:08] + quality: 20.00 (RF)
[13:01:08] * audio track 0
[13:01:08] + decoder: Unknown (AC3) (5.1 ch) (track 1, id 1)
[13:01:08] + bitrate: 448 kbps, samplerate: 48000 Hz
[13:01:08] + mixdown: Dolby Pro Logic II
[13:01:08] + encoder: faac
[13:01:08] + bitrate: 160 kbps, samplerate: 48000 Hz
[13:01:08] encx264: min-keyint: auto (24), keyint: 240
[13:01:08] encx264: encoding with stored aspect 1/1
[13:01:08] encx264: Encoding at constant RF 20.000000
[13:01:08] reader: first SCR 11520 id 1 DTS 11520
No accelerated IMDCT transform found
[13:07:33] reader: done. 1 scr changes
[13:07:35] work: average encoding speed for job is 37.107548 fps
[13:07:35] sync: got 14315 frames, 14339 expected
[13:07:35] mpeg4-decoder done: 14315 frames, 0 decoder errors, 0 drops
[13:07:35] render: lost time: 0 (0 frames)
[13:07:35] render: gained time: 0 (0 frames) (0 not accounted for)
x264 [info]: frame I:153 Avg QP:13.17 size:261455 PSNR Mean Y:50.60 U:54.54 V:55.36 Avg:51.54 Global:49.74
x264 [info]: frame P:11384 Avg QP:17.56 size: 29336 PSNR Mean Y:46.71 U:50.31 V:51.05 Avg:47.59 Global:46.62
x264 [info]: frame B:2778 Avg QP:23.32 size: 9097 PSNR Mean Y:45.38 U:51.52 V:52.28 Avg:46.36 Global:43.99
x264 [info]: consecutive B-frames: 69.5% 4.3% 26.2%
x264 [info]: mb I I16..4: 37.1% 0.0% 62.9%
x264 [info]: mb P I16..4: 3.2% 0.0% 2.2% P16..4: 34.3% 7.3% 4.7% 0.0% 0.0% skip:48.2%
x264 [info]: mb B I16..4: 1.7% 0.0% 1.0% B16..8: 19.6% 3.9% 0.3% direct: 5.9% skip:67.5% L0:40.4% L1:47.9% BI:11.8%
x264 [info]: coded y,uvDC,uvAC intra: 45.6% 57.7% 29.2% inter: 12.5% 15.3% 2.8%
x264 [info]: i16 v,h,dc,p: 44% 23% 15% 18%
x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 28% 17% 19% 5% 7% 8% 6% 6% 5%
x264 [info]: i8c dc,h,v,p: 50% 22% 20% 8%
x264 [info]: Weighted P-Frames: Y:1.3% UV:0.6%
x264 [info]: ref P L0: 76.4% 11.5% 12.1% 0.1%
x264 [info]: ref B L0: 69.8% 30.2%
x264 [info]: ref B L1: 90.2% 9.8%
x264 [info]: SSIM Mean Y:0.9904900 (20.218db)
x264 [info]: PSNR Mean Y:46.492 U:50.592 V:51.334 Avg:47.390 Global:45.993 kb/s:5355.92
[13:07:35] mux: track 0, 14315 frames, 399230565 bytes, 5355.44 kbps, fifo 8
[13:07:35] mux: track 1, 27955 frames, 11926667 bytes, 159.99 kbps, fifo 512
[13:07:35] libhb: work result = 0
Rip done!
High is what the other encodes in the chart were done at so it is fine.
The Big Buck Bunny encode is 37.11FPS which puts it half way between a Phenom II X6 1100T and a Xeon E3-1270. So again it looks like a 3.6GHZ Phenom II X6 should be around the same speed.
Thanks again.
Well, Battlefield 3 is here - lets see how Bulldozer does in that, since many were claiming it would do well.
I have a feeling it will get beat by an i5.
Most games have been GPU limited for a long time so it should be fine at standard gaming resolutions really, games like WoW which need raw IPC will struggle though obviously.
I still don't see any appeal for BD over 1090T/2500K, it's better/equal in too few scenarios to justify the extra cost.
Good point, I just remember a lot of people saying it would do well in BF3.
But it's GPU limited as you said, so doesn't really matter.
Actually.
BF3 is GPU limited, I do believe that AMD's PCI-E implementation, for whatever reason, seems to yield better results in GPU limited situations, they could be ahead by a frame or two.
Yet, if you make BF3 none GPU limited, then it'd be interesting.
Too expensive for its performance level in current software.
Well what can they price it at? It's still below par.
??? Price it the same level as a Phenom II X6 1075T or 1090T for the FX 8 core series.The FX 4 core series should be around Athlon II X3 or X4 level. The FX 6 core series is around Athlon II X4 level.
£70 like an i3.....oh wait the i3 is still faster :(, so then I guess £35
A socket 1155 Core i3 has NEVER been £70 - I have a Core i3 2100 myself. The lowest a Core i3 2100 had gone down to is around £85 and generally it is around £90 to £95. If you can get one for £70 from a reputable retailer please tell me as a mate of mine might be interested in getting one for that price.
But as Gareth showed, in gaming, and the majority of stuff, the FX8150 is no faster than his 1090T, actually slower, and that's at 130 quid.
