25 Oct 2011 at 14:40 #1 Mr.Mccoy Mr.Mccoy Associate Joined 1 Aug 2011 Posts 421 Location Bristol. Hey there! What size SSD would I need to instsll windows 7, would a 64gb one be fine? Thanks, Mr.Mccoy.
25 Oct 2011 at 14:41 #2 iNPUt iNPUt Associate Joined 9 Jun 2009 Posts 1,815 Location London Yes with room for about 40 GB of other stuff.
25 Oct 2011 at 14:43 #3 Mr.Mccoy Mr.Mccoy Associate OP Joined 1 Aug 2011 Posts 421 Location Bristol. iNPUt said: Yes with room for about 40 GB of other stuff. Click to expand... Would I see a performance increase is games that are installed on there?
25 Oct 2011 at 14:44 #4 Adam_101 Adam_101 Associate Joined 11 Oct 2011 Posts 1,421 Location UK 64gb should be fine think its about 20gb for w7 on that.
25 Oct 2011 at 14:55 #5 Mr.Mccoy Mr.Mccoy Associate OP Joined 1 Aug 2011 Posts 421 Location Bristol. If you install games on an SSD will it perform better?
25 Oct 2011 at 14:56 #6 geon106 geon106 Associate Joined 23 Dec 2010 Posts 415 Location Newcastle, Staffordshire iNPUt said: Yes with room for about 40 GB of other stuff. Click to expand... My 64GB Vertex3 has just under 20GB after a fresh Win7 install. Then with drivers and software etc i have about 14-15GB
25 Oct 2011 at 15:11 #7 Blue160 Blue160 Soldato Joined 26 Oct 2010 Posts 3,000 Location Leatherhead Mr.Mccoy said: If you install games on an SSD will it perform better? Click to expand... The only difference will be in loading times. It won't have any effect on frame rate.
25 Oct 2011 at 15:35 #8 Mr.Mccoy Mr.Mccoy Associate OP Joined 1 Aug 2011 Posts 421 Location Bristol. Blue160 said: The only difference will be in loading times. It won't have any effect on frame rate. Click to expand... Thanks, faster load times would be awesome.
25 Oct 2011 at 17:26 #9 One Hit Wonder One Hit Wonder Associate Joined 22 Oct 2011 Posts 1 Location Oakham, Rutland God yeah, 64 gigs is alright. I noticed a large improvement in terms of loading times going from my Maxtor 500GB HDD to my SSD.
