# Windows GUI 0.9.5 2011010300
# Running: Microsoft Windows NT 6.1.7600.0
# CPU: AMD FX(tm)-8150 Eight-Core Processor
# Ram: 4056 MB
# Screen: 1920x1080
# Temp Dir: G:\Temp\
# Install Dir: C:\Program Files (x86)\Handbrake
# Data Dir: C:\Users\gareth\AppData\Roaming\HandBrake\HandBrake\0.9.5.3728
# CLI Query: -i "G:\downloads\big_buck_bunny_1080p_surround.avi" -t 1 -c 1 -o "G:\mkv\big_buck_bunny_1080p_surround.mkv" -f mkv --strict-anamorphic -e x264 -q 20 -a 1 -E faac -6 dpl2 -R Auto -B 160 -D 0.0 -x ref=2:bframes=2:subq=6:mixed-refs=0:weightb=0:8x8dct=0:trellis=0 --verbose=1
# User Query: False
[13:01:08] hb_init: checking cpu count
[13:01:08] hb_init: starting libhb thread
HandBrake 0.9.5 (2011010300) - MinGW i386 -
http://handbrake.fr
8 CPUs detected
Opening G:\downloads\big_buck_bunny_1080p_surround.avi...
[13:01:08] hb_scan: path=G:\downloads\big_buck_bunny_1080p_surround.avi, title_index=1
libbluray/bdnav/index_parse.c:157: indx_parse(): error opening G:\downloads\big_buck_bunny_1080p_surround.avi/BDMV/index.bdmv
libbluray/bluray.c:960: nav_get_title_list(G:\downloads\big_buck_bunny_1080p_surround.avi) failed (0x1b4aa20)
[13:01:08] bd: not a bd - trying as a stream/file instead
libdvdnav: Using dvdnav version 4.1.3
libdvdread: Encrypted DVD support unavailable.
libdvdnav
VDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.IFO failed
libdvdnav
VDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.BUP failed
libdvdread: Can't open file VIDEO_TS.IFO.
libdvdnav: vm: failed to read VIDEO_TS.IFO
[13:01:08] dvd: not a dvd - trying as a stream/file instead
Input #0, avi, from 'G:\downloads\big_buck_bunny_1080p_surround.avi':
Metadata:
encoder : AVI-Mux GUI 1.17.7, Aug 8 2006 20:59:17
JUNK :
Duration: 00:09:56.45, start: 0.000000, bitrate: 12455 kb/s
Stream #0.0: Video: mpeg4, yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 24 tbr, 24 tbn, 24 tbc
Stream #0.1: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
[13:01:08] scan: decoding previews for title 1
[13:01:08] scan: audio 0x1: AC-3, rate=48000Hz, bitrate=448000 Unknown (AC3) (5.1 ch)
Scanning title 1...
[13:01:08] scan: 10 previews, 1920x1080, 24.000 fps, autocrop = 0/0/0/0, aspect 16:9, PAR 1:1
[13:01:08] scan: title (0) job->width:1920, job->height:1072
[13:01:08] libhb: scan thread found 1 valid title(s)
+ title 1:
+ stream: G:\downloads\big_buck_bunny_1080p_surround.avi
+ duration: 00:09:56
+ size: 1920x1080, pixel aspect: 1/1, display aspect: 1.78, 24.000 fps
+ autocrop: 0/0/0/0
+ chapters:
+ 1: cells 0->0, 0 blocks, duration 00:09:56
+ audio tracks:
+ 1, Unknown (AC3) (5.1 ch) (iso639-2: und), 48000Hz, 448000bps
+ subtitle tracks:
[13:01:08] 1 job(s) to process
[13:01:08] starting job
[13:01:08] sync: expecting 14339 video frames
[13:01:08] job configuration:
[13:01:08] * source
[13:01:08] + G:\downloads\big_buck_bunny_1080p_surround.avi
[13:01:08] + title 1, chapter(s) 1 to 1
[13:01:08] + container: avi
[13:01:08] + data rate: 12455 kbps
[13:01:08] * destination
[13:01:08] + G:\mkv\big_buck_bunny_1080p_surround.mkv
[13:01:08] + container: Matroska (.mkv)
[13:01:08] * video track
[13:01:08] + decoder: mpeg4
[13:01:08] + frame rate: same as source (around 24.000 fps)
[13:01:08] + strict anamorphic
[13:01:08] + storage dimensions: 1920 * 1080 -> 1920 * 1080, crop 0/0/0/0, mod 0
[13:01:08] + pixel aspect ratio: 1 / 1
[13:01:08] + display dimensions: 1920 * 1080
[13:01:08] + encoder: x264
[13:01:08] + options: ref=2:bframes=2:subq=6:mixed-refs=0:weightb=0:8x8dct=0:trellis=0
[13:01:08] + quality: 20.00 (RF)
[13:01:08] * audio track 0
[13:01:08] + decoder: Unknown (AC3) (5.1 ch) (track 1, id 1)
[13:01:08] + bitrate: 448 kbps, samplerate: 48000 Hz
[13:01:08] + mixdown: Dolby Pro Logic II
[13:01:08] + encoder: faac
[13:01:08] + bitrate: 160 kbps, samplerate: 48000 Hz
[13:01:08] encx264: min-keyint: auto (24), keyint: 240
[13:01:08] encx264: encoding with stored aspect 1/1
[13:01:08] encx264: Encoding at constant RF 20.000000
x264 [info]: using SAR=1/1
x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.2 SSEMisalign LZCNT
[13:01:08] reader: first SCR 11520 id 1 DTS 11520
x264 [info]: profile Main, level 4.0
No accelerated IMDCT transform found
[13:07:33] reader: done. 1 scr changes
[13:07:35] work: average encoding speed for job is 37.107548 fps
[13:07:35] sync: got 14315 frames, 14339 expected
[13:07:35] mpeg4-decoder done: 14315 frames, 0 decoder errors, 0 drops
[13:07:35] render: lost time: 0 (0 frames)
[13:07:35] render: gained time: 0 (0 frames) (0 not accounted for)
x264 [info]: frame I:153 Avg QP:13.17 size:261455 PSNR Mean Y:50.60 U:54.54 V:55.36 Avg:51.54 Global:49.74
x264 [info]: frame P:11384 Avg QP:17.56 size: 29336 PSNR Mean Y:46.71 U:50.31 V:51.05 Avg:47.59 Global:46.62
x264 [info]: frame B:2778 Avg QP:23.32 size: 9097 PSNR Mean Y:45.38 U:51.52 V:52.28 Avg:46.36 Global:43.99
x264 [info]: consecutive B-frames: 69.5% 4.3% 26.2%
x264 [info]: mb I I16..4: 37.1% 0.0% 62.9%
x264 [info]: mb P I16..4: 3.2% 0.0% 2.2% P16..4: 34.3% 7.3% 4.7% 0.0% 0.0% skip:48.2%
x264 [info]: mb B I16..4: 1.7% 0.0% 1.0% B16..8: 19.6% 3.9% 0.3% direct: 5.9% skip:67.5% L0:40.4% L1:47.9% BI:11.8%
x264 [info]: coded y,uvDC,uvAC intra: 45.6% 57.7% 29.2% inter: 12.5% 15.3% 2.8%
x264 [info]: i16 v,h,dc,p: 44% 23% 15% 18%
x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 28% 17% 19% 5% 7% 8% 6% 6% 5%
x264 [info]: i8c dc,h,v,p: 50% 22% 20% 8%
x264 [info]: Weighted P-Frames: Y:1.3% UV:0.6%
x264 [info]: ref P L0: 76.4% 11.5% 12.1% 0.1%
x264 [info]: ref B L0: 69.8% 30.2%
x264 [info]: ref B L1: 90.2% 9.8%
x264 [info]: SSIM Mean Y:0.9904900 (20.218db)
x264 [info]: PSNR Mean Y:46.492 U:50.592 V:51.334 Avg:47.390 Global:45.993 kb/s:5355.92
[13:07:35] mux: track 0, 14315 frames, 399230565 bytes, 5355.44 kbps, fifo 8
[13:07:35] mux: track 1, 27955 frames, 11926667 bytes, 159.99 kbps, fifo 512
[13:07:35] libhb: work result = 0
Rip done!
HandBrake has exited.
