MSI Afterburner is better than Fraps
17 Aug 2009
Finchley, London
I never realised till tonight that Afterburner does game video capture. It's better than Fraps, more options for changing framerate. In Fraps, it's difficult to play while it's recording since it drops the framerate drastically. With Afterburner, I increased the framerate to 40fps at half frames and reduced quality to 60% from default 85%. The result is decent enough recording quality with smooth framerate and I barely notice the framerate drop whilst playing. This is version 2.2.0 beta 8, and it records audio too, whereas earlier versions don't, so get this beta if you haven't already.
70% quality, 45 fps and full frame.
Get maybe 5fps drop at most?
Not sure tbh, I think you'd have to experiment. In F1, I think I dropped about 20 fps from about 59 to 39, but it wasn't detrimental to playing like Fraps is.
Dxtory is far better than both for recording in my opinion, barely slows the framerate at all for me on full size and quality.
That's interesting, definitely worth a try. Is the download time limited since there's a 'buy' button?
I think the trial puts a logo on videos, can't remember for sure now though. Well worth a purchase though, same price as fraps and much better :)
I discovered this once by accidentally pressing the record button. Took a while of hunting to discover why my ssd was suddenly full :p
Fraps is exceptionally good at consuming hard drive space.
Got to 500GB not long ago before deleting the whole folder.
Most of what I record is crap anyway :p
I use Afterburner too, although I found moving the Save directory in Fraps helps a lot.
Set it to somewhere other than your system drive helps immensely.
