Sorry about this rather noobish question. You can just flick a switch to get extra shaders? Or is that the same as unlocking?
ATI have stopped the bios unlock on the latest cards, so more or likely, if the card is new then it won't unlock.
UNLOCK AT YOUR OWN EXPENSE... YOU WILL LOSE WARRANTY STRAIGHT AWAY!
I used this on my non reference 6950 msi twin froz ii and it unlocked.
With the toxic, if it works then when you match the clocks, yes it's essentially a 6970 as it has 8+6 pin pcie power connectors.The switch won't magically overclock your graphic card to 6970.... or will it?
