Yep, they are working fine for me.
Anyone tried these?
  Also saw Tealc-UK playing a very cautious few rounds earlier
  would have said hi but haven't figured out the voip set-up in game yet :S
 but i was playing online lastnight lolEr, "You were kicked from the server by an administrator" - constantly as of today.
Little help?
For the VPN check are you definitely turning OFF Origin before you change your Proxy setttings?
Right-click the icon & Exit the program from your system tray.
Then do the Proxy settings.
Restart Origin, start BF3 via the icon in Origin & run through the date check. I also found turning off Cloud sync for BF3 may help.
It still may fail, but do the check again. Took one member of XSG 3 goes before it unlocked correctly.
After unlock. Shut down Origin, turn off the Proxy & then restart & you should be good to go from that point onwards.
I have a simple rule regarding multiplayer games. If you want it, get it at the beginning. Your enjoyment will diminish faster than the price, as by the time you get it, the regular players will be very competent and you will get your arse handed to you and not enjoy it.
Age of game / price / enjoyment all go hand in hand.
Is anybody else currently downloading on Origin? It started off going at around 2Mb/s and is now down to around 300KB/s. I have disconnected my router, restarted the computer and Origin and still the same. I guess traffic must be high at the moment.![]()
cheers mate, did they fix stuff like stuttering? If you had problem to begin with
