Cable shrugs, IMO it's an awful exercise, DB/BB all the way!
12/10/8, with a 5 second pinch at the top of the pull on the last rep, yowzer!
Agree but these are not conventional cable shrugs
i do them on here for cable
Board pressing is a good tool, but good honest heavy tricep work would probably be sufficient. Do you do close grip bench? BTW the "powerlifting" definition for CG bench doesn't require you to go very narrow, for example I bench with the rings in between my index and middle finger, CGBP with index finger just off the knurling.
These type of routines are based solely around the big compounds for a reason and adding additional exercises will likely impact on your overall gains. Just keep upping the weight slowly each week, concentrate on your form and it will get tough sooner rather than later.I've been alternating between those two workouts and the weights are increasing all the time. However, I can't help but feel that I'm not really doing much. Is there anything I should add? I'm thinking about adding push ups, pull ups and chin ups.
It's an excellent variant of the row although it requires very strict form to maximise gains.What is your opinion on doing the pendlay row instead of the bent-over barbell row?
As above, follow the routine exercises for exercise, set for set, rep for rep and don't change a thing until you develop a better understanding of each lift, the techniques involved and what your body's capable of.Should I continue doing 3x5 with the deadlift or do just 1x5 with heavier weight?
http://stronglifts.com/how-to-perform-the-pendlay-row-with-correct-technique/
