Can anyone tell me anything about the PD130 engine?
It runs on the wrong fuel and sounds like a bag of spanners.
Thanks for the advice. I do know the cars are different and generally wouldnt be looked at by the same person but there are reasons for that.
The Leon idea comes from needed to cart family around but also wanting something that will go when I put my foot down and the Passat was a (potentially) more sensible option.
Do you have to SORN an ostrich?
Depending on what year/model then the engine in the Leon will be either a BAM (cupra R) or AGU most likely. BAM will map to about 270hp easy. AGU and any other 150hp 1.8t engine in the vag range will map to about 200hp, and could achieve 220hp with a forge 007p valve and turbo back exhaust.
My Cupra is an AUQ with K03S.
