Corsair Vengence 8GB LP or big headspreader?
12 Jan 2009
I have an AC Turbo 7 CPU cooler and so one of the memory modules is kind of covered by the giant fan. I want to upgrade to 8GB of RAM and so these: http://www.overclockers.co.uk/showproduct.php?prodid=MY-300-CS&groupid=701&catid=8&subcat=1517
I'm not sure of this RAM will fit. So I've been looking at the low profile ones but want to know as my i5 750 is overclocked to 3.7Ghz will the low profiles be able to run cool enough at their higher speed (I think its 1580Mhz).
Ditto to the above - if you have concerns about height and don't need to aesthetically match your memory to your board then save yourself the headache and get low profile dimms.
Running at 1600 MHz at ~1.5V you wont get any real benfit from high profile spreaders.
Both sets Surveyor linked to are proven quality sets and can run happily sub 1.58v (if that is your want).
Dammit! Accidentally got the 1.65v instead of 1.5v :( Could this be a problem for my i5 750 being overclocked to 3.7Ghz? Or are ram and CPU overclocks separate now? Will my motherboard (p7p755d pro) automatically lower the voltage to 1.5v?
I bought this: CMX8GX3M2A1600C9
This is what I get for not buying from OCUK :(
EDIT: That Corsair website I linked to says: Tested Voltage 1.65 SPD Voltage 1.5, does that mean the memory runs at 1.5v but is capable of running at 1.65? They had the same RAM at 1.5v which was £2 cheaper so I think this may be the case.
The SPD voltage of 1.5V is for the SPD speed of 1333MHz.
The tested voltage of 1.65V is for the tested speed of 1600MHz.
But, as I said, it will usually run 1600MHz at ~1.5V.
Those are blue where as the ones I linked to are black. Also will my motherboard (Asus P7P55D) automatically set the voltages to 1.5v or will I have to manually do it in the BIOS?
Images are for illustration purposes only.
The RAM you've bought and the RAM sold by UK are exactly the same product.
Using the SPD settings will default to 1333MHz @ 1.5V.
Using the XMP profile will default to 1600MHz @ 1.65V.
So you want to manually set 1600MHz and ~1.5V.
Thanks mate :) Will give this a go tonight. I don't understand why these 1.65v ones exist? If you can run 1600Mhz at 1.5V why would you want to run the same speed at higher volts?
The RAM is tested at 1.65V and that's what they're rated for.
It just happens that they'll run with less volts.
Put in the 1.65V ram and my mobo defaulted to 1.65v. I manually changed it to 1.5V and its still working :) Cpu-z shows the same values as my old 4GB ram did in terms of 9-9-9-24 and it running at 782Mhz (times by two is 1564Mhz which I think is 1600Mhz but CPU-Z doesn't measure it accurately). Thanks for all your help Surveyor :)
Glad to have helped :)
Ideally the RAM should be 800MHz doubled to 1600MHz so presumably your Base Clock is slightly off.
If you have a look in the BIOS for a setting called "Spread Spectrum" you can disable this and it might even out the clock speed.
I disabled CPU Spread Spectrum (couldn't see a DRAM Spread Spectrum) but the ram is still running at 1564Mhz. In the BIOS DRAM frequency seems to be set to 1564Mhz, the other values are 1950Mhz and 1780Mhz. I can't seem to edit this to 1600Mhz.
EDIT: It appears the BLCK frequency determines the RAM speed. I'm scared to make it higher in case it fires my CPU/Board.
According to CPU-Z I should be running the ram at 1.65V as it showd 1600Mhz running at this voltage... I'm confused :(
To get your RAM to 1600MHz the BCLK would need to be 200MHz which would also overclock the processor by another 2.5%.
If you don't want to push it any further then just leave it.
You're not missing out on much.
Why be confused?
As I said earlier that's the voltage they test it at and use in the XMP profile but in practice it will run at lower voltage.
If you've set 1.5V and it's running fine then you have nothing to worry about.
Why be confused?
OK cool, I can get a bit anal about my rig. Spent a lot of time and money building her just the way I want. Thanks again mate, your a real asset to these boards :)
Thank you for the kind comments.
I hope you enjoy the upgrade :)
I certainly am! Loaded up BF3 and noticed I'm only using 1600MB of VRAM where as before the RAM upgrade it was 1950MB. So I increased some settings to Ultra and the FPS has stayed the same more or else. But the best thing is the stuttering has gone!
The only think I can think of is the extra RAM has allowed the game to buffer the textures and so I no longer run out of VRAM :)
