Is there any word on how laptop GPUs handle the game, particularly the GTX560m? I'm looking to play with a resolution of 1366x768.
Does anyone else get this problem........
When I go to Video settings and adjust the settings I save it which then puts up a banner asking "Do you want to save these settings" but the screen freezes and I have to Conrol,Alt Delete ?
Get the 470's clocked mate,[email protected] here with a pair of stock 470s at 1920*1080p all on Ultra and getting between 55-120fps on MP 64-man maps![]()
should give a nice boost, 750mhz core on stock volts here, getting 60-140fps depending on the scenario.Get the 470's clocked mate,should give a nice boost, 750mhz core on stock volts here, getting 60-140fps depending on the scenario.
I have a massive problem where my 560Ti and i5 @4.4ghz run every game at max settings at 1680 x 1050, the beta fine too.....but not the retail version. I have tried various drivers and rolling back. You'll see it goes all weird and tries to catch up on itself, really annoying and means I can't fly anything or drive anything. Nor can I play big maps.
It starts with my trying to spawn... and it not responding, but catching up. Then when I shoot the gun you can see what happens.
Mostly happens on larger levels or when I come into contact with a vehicle - mostly of the flying variety. Then goes nuts when I try to respawn.
Any ideas? Settings are at high, with no HBAO, AA, V sync. Have tried a mixture and these settings run most of the other maps with only some stuttering, but still ruining this game for me after spending so much on my pc already.
Would changing the overclock make a difference maybe?
Hope someone can help:
I have a Q6600 OCed to 3.2ghz for Battlefield 3.
I'm seeing it use 90-100% on all cores and I believe it is bottlenecking my CF 5850's.
Anyone seeing similar with the same processor?
No matter the settings/drivers I use, my fps remains similar.
I should add that my fps is the same or higher when going to single card!
V-sync is enabled
Playing at 1920x1080, but dropping it down to 1650x1050 really doesn't seem make a difference.
The GPU usage just scales back even more in crossfire.
