Why aren't you happy with the Noiseblockers? If it's because of noise, I'd pick up either a Deepcool UF-140 or Thermalright TY-140.
or one of the 140 mm BeQuiet! or search out some Antec TrueQuiets.
Be careful with the Thermalright TY-140 a lot of users have problems fitting them as they are bigger than a standard 140mm fan.
I have only used yate loon d14sl and gelid wing 14's, the gelids are very good fans.
They have 120mm holes, so as long as theres enough space in the case, there shouldn't really be a problem.
So how is he going to fit a 120mm holed fan to a 140mm case hole?
Well, they do shift a decent about of air but they can have a bit of a clicking noise at times, seems the actual fan walks along the bearing shaft, they will have to have 140mm mounting as that is what i have, i was looking at the Bequiet and also the Scythe Slipstream, If they made the Gentle Typhoon's in 140mm flavour there would be no argument imo lol
