Caporegime
- 17 Oct 2006
Motion blur in a few recent games also makes me feel a bit qweasy after a short time.
... that and a 12 pack of beer
Was hoping that all on High (HBAO/SSAO and motion blur off) would run at 60fps constant on my 2500k and 6950@6970 at 1920x1080, but it doesn't seem to.
Its mostly 60fps, but looking across large maps or being close to explosions and smoke makes it drop down to 40-45fps. Ultra is the same oddly, doesn't seem to affect my frame rate much going down to High from Ultra.
Strange considering on my Q6600 3.2ghz with a 5850 I can run at High with HBAO and motion blur on at 1920x1080 and average around 45fps.
Large maps and explosions only dropping it to 35.
Surely your setup could do a solid 60fps.
I don't know if the game uses renderaheadlimit, but you can add it via the console:Anyone know if the game uses renderaheadlimit like BC2?
And if so, what is the default for BF3?
And would reducing it also reduce CPU usage and increase GPU usage instead?
I had the same problem as you with everything on ultra but its fine on high, after checking the ram usage it was using all 4 gig so maybe upgrading to 8gig will help.
I figured this out too today. I started using chrome in the background to launch the game, closed steam and all other processes, aero effects in win 7 and voila. Fixed the stuttering.
I have an overclockers i5 bundle at 4.4ghz on 4gb of ram, which I presume means that if I buy more ram - it will throw out my overclock and void my warranty? I am pretty sure that ram is my issue.
ram was my issue, i brought more and now its fine.
