^ Some say that it doesn't others mention that it just sharpens details like adding a sharpen layer over everything.
To open the console press the button to the left of number 1 on your keyboard, press it again to close![]()
INI TWEAKS GUIDE:[snip]
Can the key bindings be changed from somewhere other then in-game? It kinda bugs me that the left hand is mapped to the right mouse button and vice versa.
Cheers for this, looking forward to getting back from work and tweaking Skyrim to an inch of its life!
Does anyone else find the UI for items/magic/etc a bit clumsy? I've only played for an hour, but I'm not a fan on first glance. I'll give it time though...
Agreed, by assuming your character is right handed it has led to confusion as LMB is "primary weapon", as it were. Not really used swords yet, just spells, and it's slightly odd!
cant get the FOV setting to save! no matter what i do its just resets back to default so i always have to open console and type "fov 80" why isnt this changeable in a ini files? cause ive done what it says but it just doesnt save? will changing the ini file to read-only fix it?
Just checked to make sure mine was still at 90 and it is from when i set it yesterday and the games been started up a few times since then. Have to set it again each time i make a new character though.Don't know, It didn't save for me either but someone else up above said it does
(NPC/CHARACTER TEXTURE MODS)
No Dirty Bodies - Caucasian Female Races
http://www.skyrimnexus.com/downloads/file.php?id=18
Can't really mod things yet until AMD release the new CAP profile for Skyrim.
