Multiple Google Apps accounts
18 Oct 2002
Kuala Lumpur, Malaysia
I was just wondering if this is possible , I currently have around 5 different google apps domains and a bit of a pain to sign in and out between them at times, so was wondering if this is possible.
There's 2 domains which I'd like to receive mail to the same inbox, but both would require separate MyErp.com app accounts, is this possible? Or would I need to keep the 2 completely separate?
You can have multiple domains on a single Apps account.
Then just add an alias. Aliases are inter-accessible between domains on the same account.
I've got this on one domain - but on these 2 domains I need 2 seperate MyErp apps - and as far as I can tell you can only have 1 of those per account :(
Also I think you can't actually show your "From" address as being the secondary domain :confused:
