- 14 Jun 2004
Might be of interest to some, found it wise looking for some info
We had a thread started on boot times in the upcomming release of Fedora Core 5. So I decided to create a new thead on how to install Bootchart and generate your own bootchart.
If you have issues installing the bootchart software PLEASE create a thread labeled unable to install Bootchart. or if one exists post your comments there.
Step 1 Obtain the software
To start create a folder in your home folder named bchart Next download the bootchart-0.9.tar.bz2 from BootChart Download If you would like to try to build the rpm then go ahead but it requires a bunch of useless packages most users will not need ( unless you develop in java)
Save the download to your bchart folder. If firefox saves the files to your desktop open your home folder in Nautilus or what file browser you use and drag the download to the bchart folder
http://www.bootchart.org/download.html
http://forums.fedoraforum.org/showthread.php?t=90060
