Post your FTTC line stats & unlocking info
14 Oct 2003
South Derbyshire
Creating this thread for people to post their line stats that are on the FTTC service.
This thread is to gauge line speed over distance and get a better understanding of FTTC (VDSL)
Does not matter if you are on the 8c or 17a profile all line stats are welcome.
for those of you that have not unlocked the BT modem yet (not HH3)
A MASSIVE thanks to asbokid for his work in unlocking the modem and providing the firmware.
There is a guide here and firmware, you will need a google account. https://docs.google.com/viewer?pid=...rel=zip;z4;hg612_unlock_instructions_v1.3.pdf
PDF here. https://docs.google.com/viewer?pid=...rel=zip;z4;hg612_unlock_instructions_v1.3.pdf
the unlocked firmware can be downloaded here http://www.mediafire.com/?fsac1u39tey47r0
Alternative download links.
Please make sure that you use the correct firmware the SP06 or SP10 will be written on the back of your modem.
Once unlocked there is a wealth of information and a few tweaks.
Best tweak is turning off QOS which gives a nice 1mbs boost on your upload speeds.
To get better stats than the GUI of the modem use Telnet, this must be enabled in the control panel/programs&features/turn windows features on or off.
Once in telnet type in 192.168.1.1
username:admin
Password:admin
type SH
xdslcmd info --pbParams
to see what profile you are on type
xdslcmd info --show
For those of you that are already on 17a and saved their 8c stats could you please post both.
ill start.
Code:
Profile 8C
Max: Upstream rate = 17307 Kbps, Downstream rate = 47660 Kbps
Path: 0, Upstream rate = 9995 Kbps, Downstream rate = 39999 Kbps
Discovery Phase (Initial) Band Plan
US: (0,95) (696,1183)
DS: (32,687) (1192,1627)
Medley Phase (Final) Band Plan
VDSL Port Details Upstream Downstream
Attainable Net Data Rate: 17307 kbps 47660 kbps
Actual Aggregate Tx Power: - 17.7 dBm 7.7 dBm
VDSL Band Status U0 U1 U2 U3 D1 D2 D3
Line Attenuation(dB): 3.4 13.4 N/A N/A 7.8 17.6 N/A
Signal Attenuation(dB): 0.0 13.5 N/A N/A 7.8 17.6 N/A
SNR Margin(dB): 22.7 22.7 N/A N/A 10.9 10.9 N/A
TX Power(dBm): -28.3 -18.0 N/A N/A 6.1 2.6 N/A
Code:
Profile 17a
Max: Upstream rate = 35659 Kbps, Downstream rate = 97040 Kbps
Path: 0, Upstream rate = 10000 Kbps, Downstream rate = 39998 Kbps
US: (0,95) (868,1207) (1972,2783)
DS: (32,859) (1216,1963) (2792,3939)
Attainable Net Data Rate: 35659 kbps 97040 kbps
Actual Aggregate Tx Power: 2.8 dBm 13.1 dBm
Line Attenuation(dB): 3.1 15.0 21.0 N/A 8.5 18.6 29.1
Signal Attenuation(dB): 8.3 15.4 20.2 N/A 8.5 18.6 29.1
SNR Margin(dB): 22.9 22.6 22.9 N/A 21.5 22.8 22.6
TX Power(dBm): -11.6 -128.0 2.7 N/A 9.8 8.2 6.3
Thank you.
16 Apr 2004
Shropshire
Profile 8c -
Code:
# xdslcmd info --show
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 2
Max:    Upstream rate = 17383 Kbps, Downstream rate = 47004 Kbps
Path:   0, Upstream rate = 9999 Kbps, Downstream rate = 39999 Kbps
Link Power State:       L0
Mode:                   VDSL2 Annex B
VDSL2 Profile:          Profile 8c
TPS-TC:                 PTM Mode
Trellis:                U:ON /D:ON
Line Status:            No Defect
Training Status:        Showtime
Profile 17a -
Code:
Status: Showtime
Retrain Reason: 2
Max:    Upstream rate = 31485 Kbps, Downstream rate = 97084 Kbps
Path:   0, Upstream rate = 10000 Kbps, Downstream rate = 39999 Kbps
Mode:                   VDSL2 Annex B
VDSL2 Profile:          Profile 17a
TPS-TC:                 PTM Mode
Trellis:                U:ON /D:ON
                Down            Up
SNR (dB):        22.7            21.2
Attn(dB):        0.0             0.0
Pwr(dBm):        12.6            4.1
Full line stats -
25 Oct 2007
Few notes for you Locky:
I've seen several people, including myself, installing SP10 over SP06 and haveing no problems.
before and after test means getting my laptop out and connecting to the router :D.
If you have a spare ethernet port on your router you can connect a second ethernet cable to LAN2 and your router. You can then access the net and the modem at the same time.
Huawei have released the source code and manual for the modem. I'm yet to read the manual but it might contain some interesting stuff.
EDIT
Before and after disableing QOS, the before speed is now 0.2 higher than it was before I disabled QOS a few months ago, possibly due to being on 17a now.
8 Apr 2008
Berks+Powys
Got my install yesterday! First thing was to ditch the HH3, install a Routerboard 750G in PPPoE mode. Also hacked the modem to get line stats.
I seem to have pretty high ping time on the UK, between 20 and 30+ms somehow.
Still on 8c:
Code:
Max:	Upstream rate = 17296 Kbps, Downstream rate = 48804 Kbps
Mode:			VDSL2 Annex B
TPS-TC:			PTM Mode
Trellis:		U:ON /D:ON
		Down		Up
SNR (dB):	 12.1		 21.7
Attn(dB):	 0.0		 0.0
Pwr(dBm):	 7.0		-22.6
This is peak hour so not ideal speedtest...
27 Feb 2003
Shropshire
8c:
Code:
# xdslcmd info --pbParams
Status: Showtime
Retrain Reason: 2
Max:    Upstream rate = 15577 Kbps, Downstream rate = 29388 Kbps
Path:   0, Upstream rate = 9999 Kbps, Downstream rate = 26844 Kbps
Attainable Net Data Rate:      15577 kbps         29388 kbps
Actual Aggregate Tx Power:        1.9 dBm           8.3 dBm
17a:
Code:
Status: Showtime
Retrain Reason: 2
Max:    Upstream rate = 8144 Kbps, Downstream rate = 46080 Kbps
Path:   0, Upstream rate = 8081 Kbps, Downstream rate = 39996 Kbps
Attainable Net Data Rate:       8144 kbps         46080 kbps
Actual Aggregate Tx Power:        4.1 dBm          11.9 dBm
OP
14 Oct 2003
South Derbyshire
Still on 8c:
Code:
Mode:			VDSL2 Annex B
TPS-TC:			PTM Mode
Trellis:		U:ON /D:ON
		Down		Up
SNR (dB):	 12.1		 21.7
Attn(dB):	 0.0		 0.0
Pwr(dBm):	 7.0		-22.6
Very nice stats, when I first got enabled I too was getting 48mbit attainable rate, so I would day your line is sub 200 meters at that snr, I think you will get 95-99mbit on the 17a profile with a 30+mbit upload.
Have you done the QOS tweak for faster upload?
