Caporegime
- 18 Oct 2002
Another FAIL by the AMD driver team, these are rubbish for RAGE.
The only one that work are the 11.10 pre 2 and Pre 3. The official 11.10 and 11.11 drivers don't work!
Its shockingly bad support!
Its shockingly bad support that they had working Rage drivers within a day, then you upgraded to different drivers and they didn't work, and this is AMD's fault?
People really need to get a clue and REALISE what they are saying.
They don't work on the driver for a day before the release, 11.10 preview 3's have FAR MORE FIXES than the 11.10 officials, you installed OLDER DRIVERS and complained.
You have 2-3 driver teams at AMD working on different things. The 11.10 driver work does NOT start after 11.9 has released, but it will have features in it that driver teams started working on sometimes 2 months, sometimes 6 months before.
When a new game comes out they take the latest build towards the latest driver and tweak that for a new game, this would be your 10.10 preview driver, the name and date is irrelevant.
The 10.10 "official" driver would have been finalise WEEKS BEFORE and be going through validation, testing for bugs and so on. The 11.10 preview will be a NOT TESTED, maybe buggy new fixes build.
People think that a fix that gets put in to something like their rage driver will magically appear in the 11.10 final, this is NOT how it works, it might not make it into the 11.11 final.
Guys work on drivers for months, for features other than just support for the latest game.
The problem is, you had a driver that worked, you don't know how drivers are made or the timescales involved nor the testing involved, you made a completely incorrect assumption, installed a driver that would not be recommended for Rage, then get in a rage yourself.
AMD got it right, YOU got it wrong, you even stated yourself, you have a perfectly good driver for Rage....... that really is where you should have stopped. That's it, a perfectly working driver within I think it was a day of release.
disregarding BF3 as this game has to be updated too which should stop some of the issues like flashing green lines and I am sure there are some memory leaks as well.
, so all the time I was blaming these addons and it was the drivers for the AMD/ATI card causing the problems.
