Thanks for taking the time to do those benchtest
How about a direct comparison with the 2700K at similar clocks to the 3960X rjkoneill to gauge the direct power of I.B.? In the meanwhile here's my own 2600K bench results until then if you don't mind. I'm running on W7x64, my 5970 is comparable to your GTX580.
Wow, the Vantage CPU score totally outdone my [email protected], although my score was P33,073 the CPU score of 32,236 vs the 3960X 47,991 (48.87% improvement) is no fair match of 4-cores Vs 6-cores. Once the eight core server editions arrive S.B. will be the poor mans friend!
And here is the Cinebench compare which shows a huge 49% CPU gap from the [email protected] to the 3960X.
How about a direct comparison with the 2700K at similar clocks to the 3960X rjkoneill to gauge the direct power of I.B.? In the meanwhile here's my own 2600K bench results until then if you don't mind. I'm running on W7x64, my 5970 is comparable to your GTX580.Wow, the Vantage CPU score totally outdone my [email protected], although my score was P33,073 the CPU score of 32,236 vs the 3960X 47,991 (48.87% improvement) is no fair match of 4-cores Vs 6-cores. Once the eight core server editions arrive S.B. will be the poor mans friend!
Looking forward to your results...
