Performance increases in L4D2, superb, was really struggling with 300 fps![]()
Lmao!
Hope it sorts my crossfire issue as in I can no longer game in crossfire mode but that sounds more like the card and not the drivers, but here goes.....
RoEy
Lmao!
RoEy
At this rate, I am tempted to sell my 6970's and get a pair of 560Ti's.
AMD are completely unprofessional with these current driver releases.
As you probably knew, because I remember you posting in my thread, I very nearly made the jump to Nvidia.
All I can say is thank God I didn't, I love my crossfire setup and haven't had any issues with the 10.8 drivers. Really happy I decided to keep my 5870's and will probably stick with ATI for the next few years.
To have a later revision of a driver "break" something that was "fixed" in an earlier revision is unacceptable.
HEADRAT
What a difference a year makesThe quote below was posted 11th September last year.
From the thread entitled "Put off by ATi?"
This sort of thread along with the moaning certainly seems to be a common occurence, you know what they say "theres no smoke without fire"
I'll get my coat![]()
These are the shizz in BF3 with xfire. Was ~85/85 usage, now ~99/99.![]()
Sometimes I get 99% usage on my 5850s, most of the time it hovers over 70-90. Not too fussed as its 80-150fps and smooth as
Back to 11.10 for me.
BF3 running like crap with xfire 5850's on 11.11 (with and without caps).
Is that with 11.11?
11.10 with cap4. I'm a firm believer of not trying to.fix something which isn't broke. I've downloaded the 11.11 and the cap but in no rush to install.
Try disabling windows aero. Seems to cause issues with BF3 on every driver I've tried.
Further to my previous comments, it appears that the scan line/graphical corruption was not due to the 11.11 drivers, but rather, I had somehow managed to switch off my custom fan profile in Afterburner. So the card was getting a little bit too hot, what with the overclock!
I turned it back on, saved the profile, and after hours of play, I've not had it since!
I did still roll back to 11.10 drivers though as they worked fine, and I did notice some fps drops withn the new one, where there werent any before.
As an aside, is anybody running a single 6870 in eyefinity on BF3, if so, what sort of framerate are you seeing? I'm running mostly high settings, 16x AF, no AA and 3840x1024 resolution - seeing late 40s to mid 50s fps, which I think is pretty respectable. Got a score of 699 on unigine with this setup!
