Z68 Extreme 4 Gen 3 beta 1.10d bios:
http://translate.googleusercontent....id=362&usg=ALkJrhg1i9Xk_g1r9FRIM9O6frlANyW8zA
Ah, I was after the 1.21d bios that was over at xtreme systems as that seems to be a good one.
Ive got it if you need it
GUYS!!! - The 1.21d is for the non-Gen3 board - be careful !! (or maybe the Extreme 7 - its not for the Ex4 G3)
So 1.10D is latest for the Gen3 then. Asrock customer service is almost none exsistant when it comes to problem solving.
Right, I got my brand new Asrock Extreme 4 and I want to check something with you guys. Sorry if this is a stupid question but I have to check. First of all it was not sealed if that makes a difference. It was in an anti static bag but not sealed. The pins are ALL bent. But I think they are meant to be? The two L shapes of pins around the middle part of the socket all point inwards towards the center at 45 degrees. They are all perfectly bent inline with each other about 45 degrees so I can only assume this is "normal" ? I thought that pins were simply straight up vertical? Which is right? I will draw a picture and upload later. Is this what people have been struggling with the same thing? Mine are all perfectly symetrical but not vertical. I have NOT put a CPU into the slot yet all I did was open it and have a look.
I am off to google. Is it worth making a new thread about this, seems a lot of people complain of bent pins on it. I need to know asap if I need to return this within 7 days distance selling regs.
I don't think I explained it very well and it is not something that can be photographed easily even with some ridiculous macro lens. I will draw a pic and upload later.
Ok guys sorry I mean like this:
You need to look closely to recognise this from the right angle. The pins may all look symetrical and nice and even, but they actually are not at 0 degrees and vertical. Each L shape of pins tilts in the direction as above.
Ok I was being totally overly analytical then. Sorry, just because I read issues of bent pins I studied it in greater detail than I ever have and noticed they were not totally vertical. My bad. Sorry to cause alarm! So when you clamp the bracket over the cpu down onto the pins, why do they not fold down and bend under pressure if the pins are not vertical? I thought they were vertical to give strength on other sockets.
Anyway...sorry yeah. Ignore me.
I will get clocking on it tonight.
