music recording software
28 Jul 2004
llanelli , south wales
my gf daughter likes to sing and mess about with recording stuff ...... but shes lackign some major software .... and maybe a hardware
atm shes recordign stuff on a handheld camcorder ( cheap £100 ) and then transferign any video / audio to pc ... the video is fine but audio is pants tbh.
now i'm wonderign if a good webcam and music software woudl be better ? and if so whast the options ?
any help would be appreciated
dont want to go silly money , and cheaper teh better
any bit of software that can record would be fine tbh, i'd go with audacity if it's just recording her signing (without sequencing/using synths to actually make music). you'd probably need a decent-ish soundcard, but the most important thing with making a decent recording is the microphone.
it won't be cheap really, if you truly want a quality recording, but a shure sm58 mic ( about £60), and a £30+ soundcard should get things sounding much better
Have a look for:
Behringer C-1U USB
Basic, but is soundcard and mic in one - and it's a mic more designed for recording than live use. Add a stand and you're looking at < £100 for a reasonable beginners setup.
sounds good .... but teh daughter uses a laptop ..... is this still usable ? as not suer if soundcard on lappy wil do teh job
You can get USB sound cards. M-Audio are quite popular, when I've used them they've worked well.
Another option is to have a look at the Zoom H2. It's a portable recorded so you can use it away from the computer.
If you're using the sound in conjunction with video to a hand clap at the start of the film, it makes it easier to match up the audio and video when editing them together. That's why they use clapper boards in films.
Have a look for:
Behringer C-1U USB
checked on river site about that ...seems it struggle to record at a good level :(
