All depends on your Ram
All depends on your Ram, if you have 4gb or more of ram, then it's 64 bit. But, if you have 3 GB or less of Ram, then go 32 bit. Apart from that, I have found no difference between the 32bit, and the 64bit.
Memphis
Current RAM level has nothing to do with it what so ever.
If your architecture supports x64, then there is no reason not to run x64.
23rd Nov 2011 14:13
marc2003
this shouldn't be a deciding factor at all. the only reason to go with 32bit is if you have a CPU which doesn't support 64bit.
23rd Nov 2011 14:10
Even if your architecture is 64 bit enabled, there has not been any prove-able difference over 32 bit, other than the Ram. Ie Your applications are going to run at real speed, if you have a 64bit OS, over a 32 bit OS.
	Neither, go 16bit, it's the future:
Burnsy2023 Neither, go 16bit, it's the future:
