As a matter of fact, looking at this a bit more closely, the 2Gb version doesn't even maintain 30fps consistently. So basically what we've got here are two cards which can't run BF3 on ultra on a 64 man server. That's all that you can draw from these graphs - not that 2Gb is a real deal maker and that 1Gb is a deal breaker.
Again, I'd really like to see benchmarks for how these cards do without MSAA and perhaps on high instead of ultra. I would bet that there's not much difference between the two at all.
what would you say I would need to run high etc 1650x1080 with a core i5 750 @ say 4ghz and 8gb ram ? am i looking at a 2gb vram card minimum ?
my 570's use 1500ish average and 1650 peak all full settings
What was the testing methodology for this? I find the results very difficult to believe as I only have 1GB and have never seen anything close to what was posted. I don't think I've ever gone below 30fps even in the most heavy firefights.
U need to close the web browser and disable aero when runnig BF3 and u'll be down to about 1200MB (unless ur using the 2.5GB cards in which case, open as many browsers as u like).
ive been saying it for ages now 1gb wont cut it in most of the newer games unless you dont mind turning aa off, it makes almost 0 sense to buy a 1gb card now, last year most games were only using around 800mb of memory with 4xaa @ 1080p
ths year most are hovering around 950-1gb+ next year its only likely to stay the same or go higher
Is there a definitive answer that more RAM will decrease lag?
My 5870 has 1GB VRAM. My PC has an additional 4gb of RAM. I have read that by increasing my RAM, it will smooth out the game as it will use the normal RAM as VRAM when it runs out.
Any truth in this as if there is, I am going to get 8GB as seen some Corsair Vengeance Low Profile going for a silly price.
Any additional Vram data goes into your ram cache (my PC has 3 Gb system ram allocated as shared video memory for a total of 4 Gb graphics ram). This doesnt cause any lag or stutter when my Vram use would be going over 1 Gb, it goes into the system ram, with which the difference in performance between having more dedicated Vram is <5 FPS.
I'd still suggest that 1GB cards (560ti etc) would be fine for high settings in BF3 with windows aero disabled (saves hundreds of MB of vRAM).
Having said that, a 2 Gb GTX 560 ti at £195 is a fantastic buy. Prior to this they used to cost over £230, with the 1 Gb version around £175, which definitely wasnt worth it for the extra Vram.
Why bother with msaa at all? Fxaa is plenty good enough in motion, compatible to 4xmsaa on its own. Uses a lot less vram.
I would play a game that held 30fps most of the time given no choice. i would not play a game at all that only held 15fps most of the time.
It doesn't hold 30fps most of the time. It holds around 25 most of the time and has a minimum of less than 20fps. If you are happy to play with that kind of performance then more power to you but I guarantee that most people would not be happy with that.
1)So again, show me a graph or some benchmarks which show the 2Gb version performing at 50-60fps consistently and the 1Gb version not able to keep up and I'll hold my hands up and say 2Gb is really worth it.
2)But all this graph proves at the minute is that neither version of the 560Ti is capable of running BF3 on ultra on a 64 man server in HD.
[/IMG]
If it held 25 most of the time then the Avg would say 25 and not 35, even without reading the clear as day 35 text written i can see that most is in-between the 30 and 40.
