DAMN YOU!!!!!
I WANT TO KNOW!!!!
Mountain mods?
*patiently presses F5 in case central*Ive just had a e-mail and can confirm the case will be here Monday so keep a eye out for a new thread in the case project thread![]()
All will be revealed Monday evening me cleeecooo
Dont go winding Mr Cleeecooo up M lads got a lot on his plate or desk as the case maybe![]()
I'm not saying what case it is until you see it Monday evening.
There is going to a lot of money spent in this water cooling build though
What I say is this,it will only have one 64gb ssd in and the 3 x 1tb will all be external to keep the heat and noise down.
you could've watercooled the HDD!!
Out of interest, what would you have done differently?
If doing it over a few months, your budget will only keep increasing!!!
When I first selected all my bits for my initial build, my budget for WC was £250
Then when anbout to do the loop, it was £450
Now, i've spent waaaaayyyy too much
EDIT:
BTW, what case is this going in to?
Also, if you plan to replace your 6870 with a 580, there's a cheap waterblock for a 580 going in the MM now...![]()
