imgburn is free and does the job. Just make an image from the original disc and then copy it to as many DVD's as you need. Also, with you creating an image, you will always have a back up on your PC
Would they play in normal DVD players?
Thanks.
yes, they would be identical to the original
you are basically making an image on your hard drive and then using that image to burn back a copy to DVD
been using dvdshrink for a few years and its the best i have used. I use Imgburn to put the iso on disk after dvdshring has created it.
Bit of a problem when I tried to copy the image file to my computer.
Not quite sure what this means and what to do.
Thanks.
You may need to copy all files to a folder and then use imgburn to create an image from the files (add each file to the list, not the folder, otherwise it wont work when creating an image)
*Edit* If you click 'mode' at the of the main screen, you can choose build mode there.
