Smart bootcut trousers for men?
3 Jan 2009
I'm after a pair of smart black/charcoal trousers with hemming/cuffs large enough to sit comfortably over a pair of work boots. Regular fit men's trousers tend to bunch up as they don't fit over the top of my boots.
I've been unable to find any suitable smart bootcut trousers for men online. I've tried the usual suspects (H&M, Topman, ASOS, Next, River Island, etc.). Can anyone recommend anywhere else?
I find M&S straight cut to be fine over boots, they currently have some really nice ones at £25
I assume he needs boot cut as he's wearing a pair of work boots along with suit trousers?
Correct. I need to wear smart black trousers for work but I also like to wear work boots as I find them to be more comfortable and practical than formal shoes. So I need trousers that will fit over the tops of them.
you're in the same situation as a lot of doorstaff and security workers, there are plenty of trousers that will do the job
