Hi all,
I am having a blue screen of death problem with a computer I recently built.
I am saying it is BSOD by looking at the message windows shows after the reboot, althout I never actually see the blue screen itself
It happens fairly often (happened twice in less than half an hour), all I was doing was installing programs / browsing the web
Here are some pics showing the error:
This next photo shows what I see if I go to C:\Windows\Minidump:
I am assuming the others in this list are the other times it has happened.
Extra Info
- If I am not using the computer (currently writing this post on my laptop), it seems fine and does not BSOD, only seems to happen whilst I am using it
- I reinstalled Windows yesterday (that is probably why there is only 4 .dmp's in that list, I am sure it has happened more often than that but the reinstall must have wiped those ones)
- I updated the SSD's firmware yesterday, AFTER the reinstall of Windows
- Yesterday it was around midnight, I had shut down my PC and it was installing updates, so I left it. It got to update 10 of 83 then froze there, the small circle kept going round, and the two dots kept going left and right, so it wasn't totally frozen, but it would not get past update 10. I woke up at about five in the morning and it was still on update 10, so I held down the power button and turned it off as it did not seem to be getting anywhere. After this I booted up the PC and it seems to be fine (other than BSOD obviously), I mean the forced shutdown didn't seem to do any damage. On the previous Windows installation the BSOD issue was happening too, so it is not the forced shutdown that caused it
The reason I reinstalled Windows was as I was having an issue with MS Office, because it BSOD'd during the install and wouldn't let me install it. So I reinstalled Win 7. I still cannot install Office on the SSD (keeps bringing up errors), but have it installed on the HDD instead.
THEN as the BSOD issue was still happening, I thought it must be the SSD firmware causing it, so updated that AFTER the Windows reinstall, but it still does BSOD
Any ideas ?????
Full system specs are:
i5 2500K
Asus P8 Z68 V LX
8GB Vengeance LP
Gelid Tranquillo Cooler
1GB GTX 460
1TB Samsung Spinpoint F3
120GB Agility 3 SSD (with latest firmware, 2.15)
Samsung Blu-Ray Drive
Akasa Bluetooth Card Reader
Antec TruePower New Modular 550W
Thanks for your help in advance,
Extra Info
Any ideas ?????
i5 2500K
Asus P8 Z68 V LX
8GB Vengeance LP
1GB GTX 460
