had a look at firesupport? seems a little cheaper than you saw... that is if i looked up the right thing? firesupport are not always cheapest but they certainly have most bits and bobs you could think of.
http://www.fire-support.co.uk/product/guarder-aluminum-slide-for-marui-hicapa-51--bla
http://www.fire-support.co.uk/product/guarder-aluminum-slide-for-marui-hicapa-51-kimber
http://www.fire-support.co.uk/product/guarder-aluminum-slide-for-marui-hicapa-51--ops-black
you can usually make a big saving by buying from hong kong, i guess it can be risky but i've received all the stuff i've ever ordered with no hassles.
lots more choice to: http://shop.ehobbyasia.com/accessories/pistol-slide-barrel-body/for-tokyo-marui/index.html?limit=all
http://www.ebairsoft.com/airsoft-parts-marui-custom-gunparts-c-68_95.html
i've got a alu slide for my glock
can't decide on a silver or black inner barrel though.
. I think i'll also have a look at HK stores as well as i do order a lot of other stuff from there and have had no problems.
. I'd say black or silver barrel would both look good. If you went for a black slide then a silver barrel looks better, just to add a bit of contrast. Thinking of getting a black slide and silver barrel myself.
