i played this last night to get a break from fifa, and tbh i hated it.
you can no longer camp and if you run around you get shot by snipers.
where did all these snipers come from? they are using the auto sniper, with silencer and assasin pro, etc. and then proning in certain ares or crouching in them where it is actually impossible to see them.
this one guy kept running back to the same spot and wiping out everyone. he was impossible to see, so hard in fact i had to watch the kill cam, and i noticed i had ran right in front of him (past him) without noticing he was there, he then shot me in the back.
i went back to the same position and whilst looking for him was shot, he was literally impossible to see, i ended up just pre-firing into the ground.
his name never showed up when i was targeting him, so that made it worse. it basically had to guess every time and spray.
he was proning in some long grass behind a rock in the caves in the map with the african rebels. you cannot prone there, you have to prone on the path and then crawl into the space.
he was perfectly camouflaged i mean, i had to just shoot the grass every time i ran past
