Call of Duty: Modern Warfare 3
How is it easy ?
Erm, find a building, or a roof and hide under it, seriously, I can't remember the last time I was killed by one. Every map has a a building, shack or something to hide in.
You can hear the thing come well before it hits so no excuses.
I disagree, they are a joke and countless times I've been killed by them when I'm in a building.
It needs removing from the Support class, I mean it only requires 12 points which everyone should be able to get in every game yet the Assault Air strike is a lot less powerful and requires more work to get in terms of actually having to worry about staying alive as well.
Where in village do you hide ? They always kill me in buildings too, do you run blast shield ?
Either in the cave bits where the water is, or there is another cave like hiding spot, even the shacks I successfully hide in.
I don't run blast shield neither.
I rarely get killed by the stealth bombers but that doesn't mean they should be in the support list, they should not have the ability to take out an entire team with a single support streak when anybody can earn them. They even have the EMP which destroys everything in the assault list and stops them from using anymore streaks for a full minute. I don't come across them as often as everyone else because I'm usually in TDM where the game is usually over before they get anywhere near their highest streaks, but you're kidding yourself if you think those streaks are not unbalanced for that list.
I'm probably more annoyed at the fact that your own teams EMP and Stealth bomber effect you as well, the EMP flashes your screen white and the stealth bomber shakes the screen while you're trying to shoot somebody :rolleyes:
I agree the stealth bomber effect is more visually distorting for your own team initially imo so you best call out before it comes in. The support streak is one thing that keeps me from jumping into Domination solo all the high rewards are virtually guaranteed.
I saw a tube video with some Americans on Dom calling in 6 EMPs at once which made the enemy team quit. Maybe funny, but can you imagine how difficult it is to play against if they called them in sequentially for the last 6mins of a match. I would like to do it sometime though :p
How is it easy ?
Here is an example I was kinda lucky another bomb landed just forward of the back corner of the container. I really hope they don't take out the colour blind assist warning.
I had a few rounds last night using the PP90M1 & finished 16/4 15/5 etc Usually I'm happy to break even at 10/10 but the PP90M1 with Rapid fire kicks ***** if your a mad rusha like me. :p
It almost seems as if you scare people because of how quick you can move & how rapid the fire rate is. :cool:
I'm starting to warm to Arkaden like I did Terminal with the help of some Javelin spots shame you only get one shot per life in this.
Unlocked Akimbo FNG9's last night. With Steady Aim they're just ridiulous. Zero recoil on them. It's like having frikkin' laser beams attached to your arms :p
There's nothing balanced in this game. Killstreaks are unbalanced,weapons are unbalanced,maps are unbalanced,some perks are unbalanced(I'm looking at you,Assassin Pro).
Balanced maps really mean mirror images like 2Fort and Well on TF2 a bit boring imo. There are balancers for Assassin like Recon, especially it's Pro version and the Recon Drone. Even a stealth Assassin will leave a trail of skull and crossbones.
Actually it's the spawns that are unbalanced. Resistance is especially bad. The team that spawns at the top of the map has a massive advantage.
