coke in stomach?
What if it all wanted to come back out mid flight?
That's a tricky one to sort, you could either flush drugs down toilet and face getting your legs broken at the other end or down the hatch with something thats erm come out the other end.
Remember watching a story tv programme about a guy that did this, got stopped and about a few hours after complained of stomach pains and told border control he had taken some drugs, he ended up collapsing and they operated on him and found out he had a operation when he was little on his intestines and it was as a lot smaller in circumference, condom of coke got stuck and was blocking everything up.
You only go through immigraion at the other end. Once on the plane, you could keep it hidden on your person easily enough, there are no scanners on arrival.
That may be true for the UK. But Australia will give you a right good search if they have suspicions.
Also quite a few times the yanks have walked a sniffer dog up and down the immigration line.
A trick they use is to walk the sniffer dog along the luggage conveyor belt. Any suspect bags are then monitored to see who picks them up off the carousel. Even if they've merely come into contact with someone who has drugs on their person, it can leave a small trace that's detectable by the dogs.
http://www.thescottishsun.co.uk/scotsol/homepage/3989548/Man-had-2kg-of-coke-in-stomach.html
Interestign stroy but what I wonder is how do they do that?
DO they swallow some kind of capsule that does not get digested? How can this even be possible.
THen it sits in the stomach and he poos it out later just as if nothing happened?
What type of substance can be swallowed but not digested? How does this work?
ANd no Im not planning on trying it lol just intrigued
Condoms
You wrap the drugs in condoms
Swallow
Poo
Extract
Seen on every episode of border patrol
Nothing new or interesting
I'm actually most impressed with the clarity of that X-ray! It shows exactly what they want to see but without any real obstruction from the internal organs, quite a bizarre image really :eek:
when they arrest him do you think they just hold him in room until he poos?
Well no, but what you see there isn't a traditional X-ray is it. That only creates a "shadow" image. It must be a CAT scan? Less likely an MRI. Just impressed by the 3D quality of it is all!
