Which one is yours?
TINY?! Thats as big as spawn!![]()
I've been scrounging dirt for my island for about week now, and that's half the size of yours lol
Closed Connection 12/12/2011 12:47:14
Log type: Firewall service
Status:
Rule: Java
Source: Internal
Destination: External (188.165.213.219:25565)
Protocol: Java Outbound
User:
Additional information
Number of bytes sent: 104 Number of bytes received: 0
Processing time: 63547 ms Original Client IP: 172.18.65.7
Client agent: java.exe:3:6.1
Cartos!
http://linktart.co.uk/2011/12/cartography-12122011/
Now wait for the long a grueling converting process!
As many of you would know, I've been bugging people in chat to help out with a public build. Anyway, it's 60% finished now. It's an entrance to a public mine shaft, with a small farm around the outside.
As I don't have a house, I decided to put a small(ish) supply room that's private to myself. Tonight I plan to dig down into the actual mine and clear out different routes for digging. I was also thinking about putting a railway system into it, with the station being in a public storage room.
Ideas are welcome.
I must also add, I have a huge mob problem around the desert area. If anybody would be kind enough to place some more torches then I'd be super happy. The amount of sand I've had to collect is unbelievable, just to fill in creeper holes.
Yay and thank god for that, looks like my lines are spot on.
Slow slow progress though, being so big.
Can anyone circle a big clay deposit? Haven't seen any on my adventures.
Anyone here any good with mirosoft ISA? I'm trying to get minecraft to work through my ISA server, i can get as far as logging in to minecraft, downloading the latest version etc. but when i put the IP in for linktart it can't find the serverJust keep getting this back:
Code:Closed Connection 12/12/2011 12:47:14 Log type: Firewall service Status: Rule: Java Source: Internal Destination: External (188.165.213.219:25565) Protocol: Java Outbound User: Additional information Number of bytes sent: 104 Number of bytes received: 0 Processing time: 63547 ms Original Client IP: 172.18.65.7 Client agent: java.exe:3:6.1
I'm allowing port 25565, i can only assume there's a problem somewhere else though in order for the ISA to be telling me "FWX_E_TCP_NO_SERVER_REPLY"
I'm no MS server expert but presumably that's to do with the IP or port being blocked in the firewall?
Can you test by disabling one of the connections temporarily?
I'm not sure how you would easily make Minecraft use one connection or another - it's always been a bit woolly for me with that and Windows.
Sadly i can't![]()
Surprised no one's coded something for this yet, i can run it fine if i use openvpn to a server somewhere but it's quite slow unless using a paid service. I might try leaving my PC on tomorrow and setting something up with that to see if it's any quicker...though my internet connection at home is pants
I've always hated java based programs!
