- 3 Sep 2003
I'm currently working on a Tamiya 1:12th Scale Yamaha YZF-R1:
All brush painted (bike frame was already chromed by Mr Tamiya).
Interestingly I find Tamiya Acrylic paint a lot easier to brush paint if I add about 0.5ml of Windowlene to the pot. I found that this makes the paint a lot easier to brush, it dries slower, and a second coat won't peel off the first. I didn't have much luck with Tamiya thinners, as I found this made previous coats of paint start to come off.
