Right i've reordered it![]()
Immersive Hud: http://www.skyrimnexus.com/downloads/file.php?id=3222
Makes the HUD fade away when it isn't needed. Nice unobstructed view of Skyrim![]()
I thought Midas Magic was always the very definition of OP. If I recall it was in Oblivion too, see no reason it won't be here either. Though Conjure Pickaxe would be very useful ><
I agree it's OP at the moment, as it's an alpha so no doubt a lot of tweaking and testing needs to be done. still as we dont yet have the CK tool it's not a bad effort just needs a lot of polish. I like the idea of the force push thing but i would rather it stagger an enemy than make them fly off like the vid shows. or maybe push them over at a higher level. It would be more efficient than using a shout as they have mixed results at times.
Anyone watch yesterdays episode of inside gaming? Apparently someone is working on a multiplayer mod?
I loved that 2k texture pack but it killed my FPS. Went back to my back up texture folder (which in itself has a LOT of HD texture mods) and my FPS went up from 20 back to ~50
Neil, are you going to edit the OP with my suggestions?
When you do, I can give you another list of mods worth installing.
