*****Official Star Wars: The Old Republic Thread*****
Got to love waiting in a queue for an hour, then it says "Connection lost"
Well played, things have finally gone **** up.
Ignore it, I had the same error.
OK ta - also just noticed the bit on the menu under 'pre order' where it says I'm OK :D
Can you tell if client is up to date or not? I've got a few weekends a go one [Fri 25th onwards]. When I try to login it doesn't say anythign about needing an update - but just want to check!
If you're looking for an end-game raiding/PVP guild then check out:
http://ocuk.enjin.com/home
We have a decent history of MMO's, currently raiding end-game in rift until max level is reached in SWTOR then will make the switch. If you're after a guild which is sociable, inclusive and also skilled at mmo endgame then maybe give us a shout.
We will be levelling at a fairly quick rate but will help others get levelled too.
Cheers.
How's everyone getting on with crafting?
Anyone found out how to do it well yet?
I've got amour crafting and scavenging.
Scavenging only finds a few resources and not the wide range of resources you need.
Reverse engineering doesn't give you blue prints, or at least everything I've reversed engineered hasn't, just gives you some of the resources back.
Other than buying some blue prints at skill trainer, I've never found any other blue prints.
Is there any public market stall things, where you can list your crafter items for sale?
About to ask the same - anyone got any tips?
Took slicing, synthweaving and treasure hunting.
This is weird, doesn't want me to play at all. Getting black screen when I load up, if I manage to pass that and get to character creation I'll get random pop up of the loading screen/logo with nothing but a mouse cursor, nothing happens in either case so I end the process, this last attempt I get in and get error 2005 which is due to server maintenance which isn't the case, the fk? Also having pauses when in the server queue (the ships pause for a few minutes) Didn't have any of this in beta...
Done the usual like update your drivers and make sure you're not trying to play it on an Acorn Electron? ;)
i am the fat kid, last to be picked, must be the only person left on OCUK who isnt in.
I am going to eat 10 packets of doritos to make myself feel better
I'll join you on the fatties bench. I finally got around to buying it on Saturday and even then it took me until Monday to enter pre order code :)
Right, i'm on Niman. Already accepted into The Immortals on the website.
Character nick is "Icicle". Please can someone invite?
Has anyone else had these kind of issues? All my drivers up to date etc (same which I would've used on the last beta weekend) I use 260 GTX, onboard sound, stock i3 2.9ghz, 4g ram, win7 32bit
