- 20 Jul 2009
- The bleak North East arm pit of Britain
Hello
OcUK needs a selection of our forum members to take on some Phobya fans that will be entering our range in the next few days!
All you need to do is take an image or two of the fan and the fan in use and then share your thoughts!
You must be able to do the above and have a case or cooler than is compatible with the fan sizes provided.
To enter all you have to do is say "im up for testing Phobya fans" along with the number associated with the fan group you want to test!
For example "im up for testing Phobya fans - Group 3"
The fans are as follows:
- 2x Phobya Nano-G 12 Silent waterproof 1500rpm Multioption (g1)
- 2x Phobya Nano-G 12 PWM Silent 1500rpm RED LED (g2)
- 2x Phobya G-Silent 12 1500rpm RED LED (g3)
- 2x Phobya G-Silent 12 1500rpm BLUE LED (g4)
- 2x Phobya Nano-G 12 PWM 1500rpm RED LED (g5)
- 2x Phobya G-Silent 14 1100rpm RED LED (g6)
- 2x Phobya Nano-G 14 Silent Waterproof 1000rpm S7 (g7)
- 2x Phobya Nano-G 14 PWM Black Silent Edition (g8)
- 1x Phobya G-Silent 18 700rpm Black (g9)
- 1x Phobya G-Silent 18 700rpm White (g10)
- 1x Phobya G-Silent 18 700rpm RED LED (g11)
Entries will close at 15:00 Tuesday 27th December 2011
Winners will be chosen at random
Good luck!
Good luck!
