- 24 Sep 2005
- Middlesbrough
Ok I'll have a look.
Who sells it?
Who sells it?
My latest razor
Also got some Bluebeards Revenge shaving cream.
Isn't the Excel a crapper razor than the Mach 3?
Just been looking at the growth pattern on my neck..
the very bottom grows upover for about an inch, then it grows in from sides to centre.. then above that grows downover. lol
I'd loath to go back to my Wilkinson Sword razor but I never had this problem with any of my previous razors![]()
What do you use at the moment?Any one have any recommendations for someone with sensitive skin? I currently only shave once a week, as if I try to shave ever 3-4 days, my skin will get irritated, spots, cuts, rashes, dry skin etc.....
What it means however is by the end of the week I start looking like a tramp!
I was thinking my solution would be to get an electric shaver? Not a cheap one tho, as I have had those in the past and they where terrible.
Any one have a recommendation of an electric shaver for some one with sensitive easily irritated skin?
This shaver is currently on offer £200 in Boots.
But is this going to solve my issue? No point me spending £200 on something that doesnt do the job.
The Sensor Excel is a 3 blade razor like the Mach 3
you said "I'm still using a Mach 3 and I'm sick of buying expensive blades."
and I gave you 2 cheap alternatives - a thank you would have been nice![]()
I have sensitive skin, the tip is to use a good razor and some decent soap. Don't use any canned stuff, as the propellants are bad. Get a DE razor and some good soap, electric probably won't make a difference.
I wet shaved the other day for the first time in years. The day after I had a red rash which deeloped into small white spots. They are now gone and rash is going away but its still itchy
How do you stop this? I used Gillette gel, Gillette Fusion shaver and hot water
Babyliss shaver/beard trimmer all the way
I use gillette fusion razer and some gillette canned foam for sensitive skin.
Whars a DE razor and what do you recommened as good soap?
Merkur 34c is a decent razor, head over to amazon for soap. I have only been using a DE for a couple of months and have been using cream from Lush. Got some soap on the way though, which I think is the one on Amazon that is £7.
My latest razor
just doing downwards strokes then had a go at going upwards took a fair few goes to prevent myself from not nicking my self but nearly perfected it now. never going back to those sh!tty multi blade razors again. never had such a close shave and the sound of when cutting those hairs just gives me that warm fuzzy feeling
Thank you
I would have replied sooner had I remembered about this thread![]()
