Call of Duty: Modern Warfare 3
IMO yes by far but as I said that is just me, a couple of the guys tried it last night anyone want to give an opinion?
Switched over to this setup last night and can confirm that the SCAR-L with silencer when used with SoH, QD & Stalker is awesome!
Now to see if I can finish off the last 5 levels of this prestige tonight....
No reply from Bad Wolf he's played for 2hrs since. 3 out of his last 10 matches 0K 1D 0A, 1K 1D 0A, 0K 0D 2A :o Should I ask him if he's a KD faker?
I didn't try it last night though have previously. Hmmmm I do like it but at the time seemed to be able to do better with a silenced ACR. Since getting used to the type 95 is nice using that silenced though, as said above, get a dodg hit detection and you are dead usually before getting another burst off. Might have to give the scar another go, the only gun in the game I like that I haven't scored nearly all the xp points from yet.
Bored at work, should have bought xbox to work to do some survival mode haha. Looks unlikely I will be going cinema tonight so fancy partying up again if you are on?
Just rage quit the game :mad:
Why are shotguns so ****ing bad, why put them in the game? I've got the Striker to level 30, and I'm using damage proficiency, and the extended mags damage bug, and it's still utterly crap, if they fix that bug they'll be even worse.
There's no benefit to using them over akimbo machine pistols at all, they are worse in every way. The bullets vanish after about 5 meters.
Sure, you can do well with them but you could do even better if you weren't handicapping yourself in the first place.
From Robert Bowling's Twitter.
Exclusive sneak peek at 'Park' - some of the first #MW3 DLC hitting Jan 24th for Elite subscribers! More info in Jan!
AhNQQ2aCEAAk-2S.jpg:medium
Am I the only one that seems to get stuck on things all the time?
First map 24th, I presume there will be a map pack shortly after this for non elitists?
I wish they had a wait for a lobby option for solo play I tried to avoid sloppy seconds, but at the 4th reset I just joined the unwinnable game, but despite wining the next one the hit detection was so bad I needed to start again.
The LMG's seem to need rapid fire to make them really viable. The MK46 seems to have reasonable stats stock, but it's going to be a bit of a grind to unlock everything. Speaking of guns you don't see much the P99 seems to be a bit of a beast pistol if you can pump the trigger fast enough.
From that picture it actually looks like a *gasp* open map!:eek:
It does annoy me that they're so rubbish now. They should have kept them as secondaries with the nerfing they've done. They should have kept them the same as they were in MW2 when making them primaries.
