We have to turn the thermostat to 17c for the boiler to kick in at the moment. Does that mean if we leave it on 10c and it gets below 10c in the house then it will kick in?
The letter itself, probably not, but it's just a reminder isn't it? If the pipes burst it would be your fault anyway because you are in charge of the property.
Shelter said:This involves making sure your home is kept reasonably well heated (in winter, it's particularly important that you don't let the pipes freeze up and burst)
Remember, it's up to you to take care of the installations. For example, your landlord may want you to empty the water tank and turn off the water in winter if you are going away, to prevent the pipes from freezing and bursting.
Is it. so if our ceiling caves in, its our fault? dont think so. They should have landlords insurance to protect them against things like this
When I was at uni, our toilet was leaking. We rang our landlord and told him. He didnt show up. Another call a week later and he didnt show up...
2 months later we rang him and told him the kitchen ceiling had caved in, about a 3 foot hole. He was around in a shot!
like its been said you cant do anything about cold water pipes so whats the point in pretecting central heating pipes?
if you're going on holiday at this time of year you're best off turning the main water supply off and draining the heating..
I belive the only way it would be enforceable would be for the landlord to subsidise the gas bill by some small ammount.
In reality its in no ones interest to have a burst pipe, but that said, it rarely (read: pretty much never) gets cold enough, especially for internal CH pipes, to cause a burst.
