£150 to go custom (single loop)
Hmm it actually works out cheaper if i get the EK 120 kit then buy another 120 rad and compression fittings.
Can i still use those compression fittings in the list with the EK 120 kit?
yeah, i'd do that TBH :p
Just make sure you order the right fittings (3/8 i think)
Okay ill check specs tonight and if you could check it over and confirm it for me, i'd appreciate it.
Cheers!
Surely your pump would have to be larger if your going to be using 2 rads? IMHO it would be so much easier to have 1 Rad.
Are you sure guys? I would mount 1 240 rad but like i said i cant mod my case to make it fit unfortunately.
Would a better pump be required?
Also would i benefit from wider tubes or does my current tubing with the kit suffice?
The current tubing is fine
A better pump won't hurt (cheap laing DDc from the MM? Jinxpad has one for £30)
Maybe an EK 4.0 pump.
an EK 4.0 pump with the tube combo sounds good for £60 odd.
Okay going to look into more before i purchase, seems i am going over my £150 budget!
I just noticed the XSPC Rasa RX120 kit is in stock, is it better than the EK 120 kit??
Yes.
Actually, they're about the same.
I'd go for the EK (mainly because of the nickel plexi :p) but also because the block is more compatible.
Th RX kit is overall better though.
