Look what Santa left me
you just have to make sure it goes in the middle hole, and out the bottom one :)
personally, i'd run it up the other way (or side on if easier) as it'll reduce the chance of bubbles getting stuck in there.
Ok thats the Rads/Res all nice and clean, now for this
And after a bit of cleaning up
can`t get a good pic of this but gpu is very SHINY :D
it goes:
top of water block with two holes
main body of gfx card
pcie connector
Well i just used the last of my TIM on the GPU mem modules so the HeatKiller will have to stay that way round until i can order more.
I have bean using the TIM i got with the Noctua cooler (pretty Good stuff) but what would you guy`s recommend? Arctic Silver 5 or something?
mx4 nice one i will order some today
in all honesty, any of the high-quality TIM's will give you good results, i usually use whatever i have spare as long as it is from a good brand - only if you are looking for hundredths of a degree would it really matter :)
btw your cpu block is the right way round and the noctua thermal paste is one of the best thermal pastes you can get
