External Hard Drive: NTFS Or FAT?
5 Jun 2005
Southampton
always had it set to NTFS, however just went to plug it into the new ps3 to copy movies and then i find out ps3 needs it to be fat32, i have spares lying around somewhere so could use that, just wondered what peoples views were on say a usb powered portable 500gig hard drive...... NTFS or Fat32?
I have my external HDD formatted as NTFS but im just wondering.... Would it be be possible to partition the HDD and format one partition as NTFS and the other as FAT32? I've never tried this myself but seems like a good idea under the circumstances.
Does anyone have an answer for this Q....
??? Anyone ???
To save me starting a new thread...
Yeah, course you can. I do this one one of my 1TB external drives, NTFS on 500GB and the other half formatted for the Mac.
Just shows up as 2 drives when you plug it in, I labelled 'em WinPart and MacPart to allow easy identification.
I think the PS3 only has trouble reading fat32 on the internal drive, if it's plugged in externally, it should be able to read it fine.
(Someone on here told me that because I originally thought it was fat32 only for the PS3)
I'd stick with NTFS
I'd stick with NTFS
Well if he wants to use it for his PS3 he can't stick with NTFS.
^He may have made the same assumption that I did, my post says that it should work fine as the external drive
Can you add a new partition without formatting the whole drive? I don't want to lose what I've already got on there...
NTFS is a microsoft file system. It will not work internally or externally with a PS3.
The PS3 has a proprietary internal HDD file system and supports FAT32 external drives and Flash drives.
I have my external drives formatted with 2 partitions. The 1st is an active FAT32 @ about 32GB then the rest as NTFS. It's handy to keep a FAT32 partition just for massive compatibility it provides plus the ability to install OS's from it :)
Pretty sure the PS3 just uses a Unix filesystem, the issue is that it's encrypted so impossible to read on another system.
