a bit later on in the same article:BBC said:some retailers stock models costing up to £110.
BBC said:Competitors both offer HDMI cables priced between £19.99 and £119.
I wish articles like this were actually checked before being published (nothing aimed at Jellybeard here):
'tards...
It was just one of the first links in google.
Oh dear, somebody in this thread splashed on a 100 quid HDMI cable and now feels a bit silly
Of course the retailers and cable companies (and therefor magazines who rely on advertising...) are going to claim there's a difference. In the old pre-digital days there was a difference. But now those same companies must be in full-scale panic mode because there is NO difference in quality with digital...at least at the lengths most consumers will need.
The thinner the cable the less well shielded it is and the more likely it will be to radiate interference to itself and any neighboring cables. Whatever thin cables you buy make sure you can return them easily. That, or fit deeper skirting scooped out at the back so you can run decently shielded stuff.Does anyone have any recommendations for thin HDMI cables that are 5m or longer? I've got to run two cables between the bottom of the skirting board and the floorboards and the thinner they are the easier that will be.
EDIT: Flat won't work. Before anyone asks!
Silly priced analog cables = load of ****
The sub was £1k so I let him convince me that it would not be at it's best if I used the cheap cable that came with it in the box, I know better now and it still winds me up when I think about it.
Because they are not digital the quality of these cables DOES make a difference, I'm not saying spending hundreds on a cable would make much of a difference over a £20 cable but the £20 cable will be a massive improvement over the nasty cables you get bundled in the box with audio equipment.
I agree with you on the other points though and I once many years ago let a salesman convince me to buy a £50 mains cable for a subwoofer of all thingsThe sub was £1k so I let him convince me that it would not be at it's best if I used the cheap cable that came with it in the box, I know better now and it still winds me up when I think about it.
maybe an eye test is in order?
Fixed.
It's a conspiracy which your brother in law is completely oblivious to. It's most definitely a set up by the managers. They've hidden it from the floor staff so they believe in the product themselves so they can sell it better.
Maybe a brain is in order?
Seriously mate, you've been well and truly ripped apart on this thread. As you haven't posted for a few days I can assume it is out of embarrasment.
