We bought a little device that measured the dampness of the log. Under 20% is fine for burning. Anything above you should leave to dry properly.
Got a link?
We have an open fire place, about the same size as the OP's, would like modernise it and use a log burner, however I have heard stories of damp chimneys where the new flue doesn't vent the chimney properly leading to damp and also size of logs, my log guy's logs are pretty long, what limits are there and do you have to order logs for log burners?
Don't have any pictures to hand - but it's the smaller version (5kW) of the one shown here:
Almost hypnotic when it's going...
Whats the total cost of getting a wood burning stove? I'm looking at a house that has a straight chimney so it would be easy to get one put in
I presume they generate quite a bit of heat? And wood barely costs anything?
Yes they can do and it depends, if you've got access to a ready supply of wood then sure it doesn't cost much more than your time but if you've got to buy it in then getting a log burner for the cost savings may not be such a good economy.
That's a fair point. But I presume you're not allowed to just go around chopping down trees for the logs? I thought everyone would have to buy it? Unless people here have private land with hundreds of trees at their disposal.
