At work they have all the machines set to lock after 10 or 15 minutes, it can be very annoying, particularly when I'm running a test that may involve me not touching the PC for an hour.
The only fix we have at the moment is a mouse move program which literally makes the mouse move every few mins, this is great unless it does it just as your about to click something.
Does anyone have a more elegant solution? The only thing I could think of was if the mouse move program had a timer set to 5 minutes and it reset if you moved the mouse yourself, that way it would never move it while you were using the computer. Is this possible?
No point in asking IT as the answer will be no, company policy.
Any help would be great, thanks
