- 7 Mar 2005
- LU7
Yep. It's just better to have an internal USB port for something that won't get unplugged that often; reduces the risk of it getting knocked out but hey-ho.Doesnt have an internal USB port, but guessing it should be fine to just plug it in the back port somewhere?
I have. Well I've bookmarked a few processors and motherboards and I think they all, if not most, support the virtual extensions as antc says.Also just to confirm with the chap who mentioned about compatible hardware and MarcLister, im pretty sure we have both checked the the cpu and mobo both have the virtual extensions required to run vmware esxi or hyper-v?
When I get to the actual purchasing next year I'll double check then.
Wishing her a rapid recovery
