Is that tera patrick in your sig?
Ninja edit!
I had a Antec 620 it started leaking coolant after a few months. Luckily no damage was done as I spotted it early. I would keep a close eye on it....
I think i am going to go for a full wc system soon, only got the 620 because of the price tbh where did yours leak from the rad or cpu block ?
Part of the side of the block split open. luckily it was just a small leak and I noticed it pronto.
^ Bit dusty in there, looks clean in terms of cable management though.
Alright so i dont know if anyone remembers when i first posted mine on here
( http://img827.imageshack.us/img827/6219/72477194.jpg )
But it had those horrible yellow and black cables everywhere and ive been
working on it since adding bits to it and just this morning put in a coolermaster 200mm fan in the front. I now want to buy another to put in the top xD
Anyway heres my case as it is now, tell me what you think
I had no idea the H60 relies on the stock motherboard plastic bracket. Seems weird?
Yea it is dusty, whats the best way of getting rid, dust buster can?
Hey, why do you use 2 CF bridges? Is it something that should be done?
some more images after using mdpc-x sleeving
SNIP
