The main uses are going to be video editing, although ill be gaming every now and then.
YOUR BASKET
1 x Intel Core i7-2600K 3.40GHz (Sandybridge) Socket LGA1155 Processor - Retail £239.99
1 x Asus GeForce GTX 560Ti DirectCU II TOP 1024MB GDDR5 PCI-Express Graphics Card **Supplied with Battlefield 3 PC Game** £191.99
1 x Asus VE247H 24" Widescreen LED Multimedia Monitor - Black £169.99
1 x Western Digital Caviar Black 1TB SATA 6Gb/s 64MB Cache - OEM (WD1002FAEX) £121.99
1 x Asus P8Z68-M PRO Intel Z68 (Socket 1155) DDR3 Motherboard £119.99
1 x Cooler Master CM-690 II Advanced Dominator Case - Black £89.99
1 x Corsair Enthusiast Series TX650M High Performance 650W '80 Plus Bronze' Modular Power Supply (CP-9020002-UK) £89.99
1 x Corsair Hydro H60 High Performance Liquid CPU Cooler (Socket LGA2011/1366/1155/1156/775/AM2/AM3) £62.99
1 x Corsair Vengeance Blue 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMZ8GX3M2A1600C9B) £39.98
1 x Asus 24x DVD±RW DRW-24B3ST SATA ReWriter - Black (Retail) £20.99
2 x Akasa AK-FN059 120mm Ultra Quiet Venom Viper Cool Fan - 3/4 Pin £13.99 (£27.98)
Total : £1,199.99 (includes shipping : £20.10).
Would like it if you could just give it a quick check and make sure its all compatible, even though I'm pretty sure it is. And if there's any components you recommend I get instead of the ones I have chosen. Cheers.
YOUR BASKET
