The moon causes tides on Earth because of the difference in the strength of mavity over the Earth - the side nearest the moon experiences a stronger gravitational attraction to the moon than the other side. The same's true of the sun to a lesser extent and I assume it's also true for the other planets to a tiny extent.
So...the weight of an object would change depending on when you measured it, as its weight would be determined by the combination of gravitational fields (Earth's, moon's, sun's, etc) and that varies. An object would weigh less when the moon was overhead than when the moon was over the opposite side of the Earth.
I'm curious as to how much difference it would make. Very little, obviously, but just how little? Or have I completely misunderstood things and it makes no difference at all?
